Results 1 to 2 of 2
Thread: Unique Bodark Bowl
    Mar 2015
    Parker County, Texas
    1,500
    Unique Bodark Bowl
    When I ripped this log, which was actually part of a branch I was not sure what to do with it. There was a gap in the outside of the wood. This is what I ended up with. The gap ended up looking like a handle of sorts. After initially hollowing it out I expanded the inside using a rotary rasp as well as smallish curved chisels. I expanded it going away from the "Handle" part as I wanted to maintain that area as it was. I even had to use a regular wood rasp on this. I might should have gone further with the hollowing out but decided against it. I filled a couple of spots on the top with crushed red coral. Those spots just seemed to need it. The outside diameter is 8 3/4" and it has a height of 3" with a depth of 2 1/4". I used my usual walnut oil to seal the wood and then polished it up with a walnut oil/shellac mixture.
    Feb 2012
    2,749
    If I made a Bodark bowl, I would call it "Humphrey."
    Cheers,
    Roger
  1. Octagon Bodark Candy/Nut Bowl
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 06-10-2015, 04:41 AM
  2. 11 1/2" Bodark Serving Bowl
    Last Post: 05-21-2015, 09:04 PM
  3. Bodark Burl Bowl
    Last Post: 05-14-2015, 12:39 PM
  4. Bodark Burl Natural Edge Bowl
    Last Post: 03-27-2015, 08:48 PM
  5. Bodark Candy/Nut Bowl
    Last Post: 03-15-2015, 04:11 PM
