Results 1 to 10 of 11
Thread: over ambitious
    Jan 2011
    Mount Vernon, Ohio
    75
    over ambitious
    I had a thought about making a different lid for a keepsake box I'm working on. It looked good in my head, looked good on paper, it even looks good after making the tedious cuts necessary and, after figuring out the compound angle cuts needed. But, I never thought about the glue up!
    Here is what I have.Click image for larger version.
ID:	90036Click image for larger version.
ID:	90037 The first is the profile I made, and the second is how they should glue up.
    Now, without spending a week or so making a gluing jig, I can't figure a way to glue these together.
    I've heard Scott Phillips talk about a "rub joint" and that he uses it often. But I think that would only work on long grain and this is definitely end grain.
    I've thought about CA but, I've never tried that on anything.
    Do any of the box builders on here have some thoughts on this? It is cherry if that makes a difference.
    Yorktown, Virginia
    5,021
    One thought is to use Titebond II and a few sets of band clamps. One set would go around the bottom side/widest part of the box as you have shown it on your second picture to secure the perimiter of the frame. Then I would wrap a set perpendicular to that totally around each of the two sides, like a Christmas present, to pull the bottom of the funnel together and secure the top piece in the groove. I might shoot a couple of pins in the joints to keep them from slipping, if I could figure out how to do it without making a dent.
    4,701
    Maybe put a couple of finish nails on the inside of one side and clip the heads so there's just a short spike sticking up to catch the other piece so it doesn't slide while clamping?
    Jan 2011
    3,798
    Hot glue some clamping blocks? If the joint fits well without needing much pressure, might get away with double sided tape instead of hot glue.
    Feb 2012
    2,749
    Quote Originally Posted by Ken Cook View Post
    Just what I was thinking. That joint looks like it fits very well.
    Cheers,
    Roger
    Nov 2012
    Wapakoneta, OH
    611
    I think I would want some kind of spline or biscuit (maybe a FF size) in there, I worry about just glue on end grain.
    5,323
    Quote Originally Posted by fred hargis View Post
    Agree with Fred. I use an older Ryobi mini-biscuit joiner for assemblies like this. if you can't use biscuits, consider using a spline across the joint. Whatever you use, some hot-glued clamping blocks will make it easier, or you could build a jig to hole the parts in place until the glue dries.
    Consider only gluing one corner at a time - Make two 'sets' of 90 glue-ups, then glue those together to make the frame/lid. Easier to manage than doing all four corners at once.
    Jan 2011
    Mount Vernon, Ohio
    75
    Thanks guys! This opened up some more brain cells.
    I'm going to try 1 corner at a time with a rubbed joint using Titebond III. Since the thickest part of this joint is only 1/2", and so short, I'm afraid any type of fastener at the angle needed would be impossible.
    Hopefully someday I'll be able to post the completed project for your approval, (or dis-approval).
    Jan 2011
    Mount Vernon, Ohio
    75
    Since you all got me thinking differently about this, I brought a couple of the mitered off-cuts in the house for a trial. (the house is where I keep my glue in cold weather)
    I "sized" the ends with TiteBond III mixed 50-50 with water. Let that sit for 20 minutes then applied the glue straight, rubbed together, and let it sit in place for 24 hours. Amazing!! The joint cannot be broken, at least by me, and there is very little squeeze-out. I think it will work.
    Now, when the wife's medical appointments slow down a bit, and Ohio weather quits demonstrating 20 plus degree changes daily, I might just get this accomplished.
    I will be back with pics as soon as it happens. (Good thing this woodworking is a hobby!)
    9,077
    Depending on stress, a spline-like strengthener or not, your decision. As to clamping, block or shaped cauls
    and one corner at a time.
  1. Ambitious Office Project
    By gavin dj harper in forum Welcome and Introductions
    Last Post: 09-20-2011, 04:17 AM
