Page 3 of 28 FirstFirst 123456713 ... LastLast
Results 21 to 30 of 272
Thread: new shop in the works
  1. #21
    Nov 2007
    Salt Spring Island, BC Canada
    2,070
    Yes that was the plan Stu. Also provides some insulation from the slab. They make a product just for this type of application. 16x16 squares with a plastic backing.
    I can only imagine that much space
    I understand the want to put in a slab it sure it easier, and down the road the space could be converted to use for cars etc, but I have to say that having made the MISTAKE of not putting a wooden floor on top of my concrete one, I would very seriously suggest that if you do end up with a slab, at least float a wooden floor on it, maybe you can't run your duct work under it, but you can surely run some wires like a wire for the tablesaw in the middle of shop etc.
    Really a wooden floor is the way to go, even on top of a slab!
  2. #22
    Nov 2007
    2,070
    Yes Fred hydro is our electric company.
    Quote Originally Posted by fred hargis View Post
    Congrats, sounds really cool. I've led a sheltered life in the states, so: "hydro" is electric (right?).
  3. #23
    3,147
    If they would let me build it as just a storage shed with plane simple construction I would & then later after inspection finish out the inside as I pleased.
  4. #24
    Jun 2007
    4,945
    Drew,
    You make me so happy that I am not building a house at this time. I think back to our first custom house---it was a "No Sweat" deal. Everything went quickly and simply.
    You have my sympathy and best wishes. Once when I had some sweat issues, Glenn said, "Dad it's a hobby. This is part of the hobby; try to enjoy it."
    Oh, I could not get any of your pics. All I could get was black and white with the little spinning circle in the middle of it.
    Enjoy,
    JimB
    VOTING MEMBER
  5. #25
    Nov 2007
    2,070
    Sorry about the pictures I am not sure why they will not load. I will try again to take more pictures and see if it is the pixel size that has some effect. I usually shoot in RAW and then convert for posting so it could have something to do with the conversion. I will try again Thanks for letting me know about the problem. Yes I remember the days when it was so less complicated. It was just a simple thing with no fancy products that seem to demand engineers to get involved. I have built things way simpler and larger in way colder climates than here with no issues at all. I really miss those days.
    Quote Originally Posted by Jim C Bradley View Post
    Drew,
    Enjoy,
    JimB
  6. #26
    4,812
    Building codes seem like they're often a mess. As one friend put it "not confusing the issue with logic".
    Hopefully you'll figure out a way past the issue and be able to get some progress in while the weather is good. I'd be tempted to say it was uninsulated and then " change my mind" post construction as well.
  7. #27
    Nov 2007
    2,070
    So back to the drawing board with the plans and have gone back to my original plans with a simple footing and perimeter foundation wall of 24 inches. Will damp proof and then back fill and frame a floor and run the ducting under the floor. Yes I will insulate at a later date once everything is passed. It is after all a shop.
  8. #28
    Yorktown, Virginia
    5,131
    Drew...I wouldn't give up without paying for an hour or so of an engineer/architects time to examine all the code compliant methods of doing what you want. You might find solutions in terms of methods and timing that are not as expensive as you think and it would give you what you want without regrets. There is usually more than one way to skin the cat.
  9. #29
    Nov 2007
    2,070
    Yes Ted I have talked with an engineer and he is tied up for the next 2 months with projects but I have told him what I am looking at doing and he said he might be able to come by and look at it next week to figure something out. Once the engineer stamps it the inspector can say nothing to how I am building it.
  10. #30
    Nov 2007
    2,070
    So after careful consideration and talking to the inspector I have decided the size of the shop that is allowable without engineering is 592 sqft which allows a 20 x28 ft shop/ garage. Am meeting with a couple of local contractors in the next two days to talk about what can be done as well as costs to what ideas they have and what they have run into before dealing with this inspector. See what kind of price they can give for just the slab and or to do all the framing. Not that I cant do that but if the price is right and I can work with them.
  1. Here's one in the works
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 03-10-2013, 06:16 AM
  2. see if this works
    By Stephen Bellinger in forum Off Topic Discussion
    Last Post: 02-11-2013, 06:38 PM
  3. OMG...it works
    By Craig Feuerzeig in forum Finishing School
    Last Post: 01-23-2007, 03:42 PM
  4. IT WORKS!!!!!
    By Jim O'Dell in forum General Woodworking Q&A
    Last Post: 11-27-2006, 12:17 PM
