Results 1 to 5 of 5
Thread: What should I do
    Jan 2014
    Arkansas
    190
    What should I do
    On the fence on this table top I am doing, it is an MDF walnut veneered table top with Cherry wood edging and I can't make up my mind if I should use a wipe on Poly, or rattle can spray Lacquer or brush on lacquer. Never done a veneer table top on MDF so not sure what I need to finish this thing, any suggestion will be appreciated.
    Southeast Pa
    2,019
    Well I can offer no advice on this. Well I could but I would be guessing which is worse than no advice
    Hopefully some on will chime in.
    13,360
    I can't offer any specific advice, but I wonder how much difference it would be from finishing some mdf veneered ply?
    I did mine with what I call the Rennie method. Basically a seal coat of lacquer, and some wipe on satin poly, and I finihsed it up with a littel paste wax.
    Ended up looking pretty decent and it's what I generally use anymore.
    Hopefully someone more skilled will chime in soon.
    Nov 2012
    Wapakoneta, OH
    611
    What is it that you're not sure? Any of the finishes you mentioned can be used, though for a table top I would go with a good varnish (either wiped on or brushed). Lacquer would be quite a bit less durable in that use.
    Austin, Texas
    1,448
    I have a chip on my shoulder using poly on a table top (my son created divots in the finish growing up).
    Lacquer is minimally adequate for a table surface.
    My usual finish now is water based conversing varnish... Target EM8000cv
    Charlie Plesums, Austin Texas
