Results 1 to 10 of 29
Thread: Welding
    East Freeetown, Massachusetts
    3,021
    Welding
    I am thinking about buying a welder.
    I don't need or want anything fancy
    I want simple to use - easy to learn.
    I am thinking mostly for my signs. \
    I will be welding light steel box steel tube - 1" square
    I will weld rebar, and the concrete mesh to rebar.
    MAYBE - aluminum - MAYBE
    I don't really want to spend a lot of money
    220 is ok - 110 is ok
    What is good and what is not
    What are the Pro's and Con's
    13,361
    I had a little 120volt generic mig and was never happy with it.
    Upgraded to a Lincoln 180HD 220v unit with a bottle of welding gas and I would not look back. I've been able to dial it down to do some thin sheet metal and have used it to weld together a little garbage cart out of 1" square tube steel.
    I went ahead and got the little spool gun I could use for welding aluminum.
    It's a nice little unit and pretty versatile.
    But I'll let the experts chime in on what they think.
    13,451
    The unit Brent posted would be my choice also, for aluminum, the spool gun is recommended as with the regular mig wand the aluminum wire gets bent/jammed too easily in the wands cable.
    4,699
    Similar unit to the Lincoln, I have the Hobart handler 140, so far it's done all I want and is pretty good for a 120v unit. Haven't tried aluminum with it yet, aluminum looks hard, and I don't have a spool gun which you'd definitely want
    3,021
    I have a lot to learn.
    A guy at work said I would be better with a 220v welder.
    I want to weld rebar
    I want to weld light duty square tubing.
    The stuff I have in mind is this stuff
ID:	90192Click image for larger version.
ID:	90189Click image for larger version.
ID:	90190Click image for larger version.
ID:	90191Click image for larger version.
ID:	90193Click image for larger version.
Name:	Sign Frame-1.jpg
ID:	90194Click image for larger version.
Name:	sign frame-2.jpg
ID:	90195Click image for larger version.
    I can sell a mailbox tree stump post for around $1500
    The signs are $1000 - $5000
    A sign like the TEAL sign with the post - around $5000 or more.
    13,361
    I figured I'd go for the 220. I know my previous 120 unit was a piece of junk, but the duty cycle made it tough to use at times.
    When I welded up my garbage cart, I had no problem at all with the duty cycle, and dialing in the speed and power was a piece of cake.
    3,021
    Something like that cart is something I would be interested in building.
    Get the 220v unit, don't look back, get the bottle set up, it welds the best by far, get a good unit, not some trash from China. Miller, Hobart, Lincoln, you can't go wrong with any of those, IMHO.
    Get good PPE, especially don't skimp on the helmet, I learned this the hard way I had a series of cheap helmets, they don't work so well and they are tiring to wear, they never stay up or come down nicely.
    I like the Jackson helmet, it is pricey but good, it is a joy to wear and you can see very well through it.
    See more about it in this thread post #8
    Buy a half decent welding jacket and gloves, you don't need something super heavy weight with the MIG, but decent gloves that you can work in.
    Buy a good cut off saw, don't skimp here either, when the saw will NOT cut at a 90 or a 45 well, you spend a LOT of time filling gaps and then sanding or grinding the extra away.
    Get a good quality 4" grinder, I went through maybe 4 cheap ones that were actually quite expensive as they did not last very long, I finally bought a good quality Hitachi unit and it has lasted for many years now.
    4,699
    And good closed toed shoes . Hot foot ain't fun!
    You might look at the local college and see if they have a welding program, it's a nice way to try out different techniques and tools before you buy.
    3,021
    Yeah - I would take a welding class
  1. Welding Wood?
    By Charles Hans in forum General Woodworking Q&A
    Last Post: 12-15-2015, 09:28 PM
  2. Welding or not? Now add some wood...
    By Garry Foster in forum Off Topic Discussion
    Last Post: 05-26-2015, 04:03 AM
  3. Welding
    Last Post: 05-20-2014, 03:31 PM
  4. Welding
    By Allen Grimes in forum Off Topic Discussion
    Last Post: 02-06-2007, 11:35 AM
