Results 1 to 2 of 2
Thread: Shopsmith mortise attachment
    Mar 2012
    Hinton Alberta
    52
    Recently I got some wheelwright books and started a hub mortising jig. It is about ĺ done and then I decided to check into the SS mortise attachment. Besides the unwelcoming price tag I have not read much good about it and certainly donít want to harm the old girl (1954 Shopsmith mark V) making it do something thatís not recommended. Anyone use this attachment and is the SS quill to weak? Some mods and I can go to the drill press but this was just too tempting and convenient. Thanks for any help/advice.
    Apr 2013
    Nashua Iowa
    130
    It takes a quite a little pressure the use the mortise attachment on a shopsmith. The problem is the table. It is not real sturdy and tends to flex away from the cutter. It is also hard to get the table clamped real solidly on amachine as old as yours and either the head or the table want to slide on the tubs. I spent the money do do it and took a bath when I sold it. Not a fan of morticing on a shopsmith. I do have 2 shopsmiths. A drill press would be a better choice but the handles are short so be prepared to go slowly. Getting on to fit your drill bress would depend on the manufacturer so be carfull if buying off from ebay.
    If you can I would go for a morticing machine. This is one place you would be better off without something with attachments.
    Wish you well
  1. Shopsmith with attachments
    By Rich Soby in forum Classified Ads
    Last Post: 10-24-2014, 07:14 AM
  2. ShopSmith Lathe Tools
    By Drew Croy in forum Turning Tool Questions and Show & Tell
    Last Post: 09-21-2010, 09:41 PM
  3. Shopsmith 4 inch jointer
    By Robert Smith in forum Old Ads
    Last Post: 06-14-2010, 02:51 PM
  4. Shopsmith on line forum
    By robert dewinter in forum Off Topic Discussion
    Last Post: 01-19-2008, 11:44 PM
  5. Shopsmith Help
    By Sandy Masquith in forum Old Iron
    Last Post: 01-19-2008, 11:06 PM
