Results 1 to 3 of 3
Thread: Vertical Lumber Storage Addition
    Jun 2007
    4,944
    Glenn dropped by and we took to the shop. For Christmas I received a coupon good for one "Lumber Rack Re-Org". I am cashing in part of that . Glenn says this one incorporates all the fixes for the mistakes he made on his first two that reside in his shop so, I got that going for me. I don't stock a lot of lumber so the width is 32". It is positioned in the shop to take advantage of an open overhead area that leads up to a high-point of the roof line. This shot shows scale and height of the back-rest / divider.
    The base is not as deep as Glenn's; I set the depth at about 9" since that will fit most of my stock.
    I set my indentured servant to loading the beast up. Now the south wall holds a lot more stuff and even has some open space on it .
ID:	90233 . Click image for larger version.
ID:	90234 . Click image for larger version.
    After lunch we'll go after the horizontal rack.
    VOTING MEMBER
    Thomasville, GA
    5,994
    Bill Arnold
    4,699
    Looks quite good there! The wood will be quite happy to be off of the floor and securely stowed and I'll bet you'll be happy with how easy it is to get at it now .
  1. More Vertical Lumber Storage
    Last Post: 10-21-2014, 01:11 PM
  2. Lumber Storage Re-org - Sense of Accomplishment
    By glenn bradley in forum Shop Tours
    Last Post: 08-31-2012, 12:56 AM
  3. Vertical Lumber Storage Method
    Last Post: 10-11-2011, 02:18 PM
  4. Building a Lumber Storage Shed at Pellow's Camp
    By Frank Pellow in forum Carpentry and Construction
    Last Post: 09-30-2011, 09:54 AM
  5. Vertical sheet good storage
    By Doug Sinjem in forum General Woodworking Q&A
    Last Post: 12-12-2006, 11:59 AM
