Results 1 to 10 of 22
Thread: A hollow form that's not a hollow form!
    Taree Australia
    37
    G'Day All
    Well its with much trepidation that I make my first post on the forum...
    I have no hollowing tools so thought I would cheat a bit.
    Turned cylinder out of a piece of Camphor Laurel (a local weed) and turned spigot on top.
    Cut into top and bottom sections
    Hollowed out bottom and shaped and turned a step at what will be join
    mounted top using spigot and hollowed lid out, and made opposite recess for joining.
    Remounted bottom with face ring that was left on and fitted lid and glued using tailstock without centre pin out.
    Used lathe as clamp while glue set.
    Then turned groove at join and filled with sawdust and CA.
    Cleaned up and finished.
    Sorry to be so long winded and hope I didn't leave anything out.
    Attached Thumbnails Attached Thumbnails IMG_0690.JPG   IMG_0691.JPG   IMG_0692.JPG
    15,815
    Don't matter how you did it Bernie, looks good!!!
    BTW, I moved your post to it's own thread, nice work like this deserves it's own place!
    30,230
    Bernie, for a local weed that's sure some pretty wood. As you've proven, there's more than one way to hollow out a piece of wood. Sounds like you had fun figuring out the process, too. Good job.
    Inside the Beltway
    2,666
    Bernie,
    Nice work! To us, that's an exotic wood! It sure came out beautiful.
    And don't worry, you're not being long-winded. To me, as a beginning turner, your description sounds like shorthand. Did you take pictures of each step???
    Bill
    11,900
    Well done and a great technique.
    Goodland, Kansas
    4,834
    Bernie that is a beauty. Weed or not to us that is exotic wood. Nice job.
    Bernie W.
    Bernie...Nice two piece hollowform. Actually there are a couple of people I've seen post pieces made that way.
    s. Barrington,IL.
    127
    Bernie nice job .Thanks for the explantion.
    Ken
    Nice Bernie, I did similar but using a contrasting piece of wood as a ring to hide the joint. I like the idea of the filler, This woold also be a good place to use some colored stone & epoxy inlay material. Nice Lidded Box with the top sealed...
    Takes the excellant grain structures of your Camphor Laurel to bring this off well.
    Thanks for the post.
    Field, Ontario, Canada
    113
    Beautiful work, I like the way the wood grain came out.
    Yann
    Anything that can go wrong will go wrong, so keep your hands away and watch out!
  1. first hollow form
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-14-2008, 02:08 AM
  2. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  3. Box? Not exactly. Hollow Form? Well, no....
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 05-12-2007, 10:28 AM
  4. The Next Hollow Form!!
    Last Post: 05-01-2007, 02:34 AM
  5. Hollow Form
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-30-2007, 10:34 PM
