Results 1 to 10 of 14
Thread: Couple Walnut Bowls
    Jul 2007
    DSM, IA
    5,719
    Couple Walnut Bowls
    Finished up a couple of walnut bowls last night. The large one (second photo) is just over 11" in diameter and the smaller one is just under 7". The smaller one I filled a crack with some coffee grounds and CA glue but the bit at the rim came out as I was wet sanding with danish oil...not sure what to do now, might just leave it alone and use it for a catch all in the shop. These are pretty thin for me, just under 1/4" ...think I'll go back to thicker ones next.
    Attached Thumbnails Attached Thumbnails IMG_20150505_201002.jpg   IMG_20150504_191831.jpg
    My Website
    Thomasville, GA
    5,994
    Nice work, Jeff! The grain balance on the large one looks great!! Even with the additional "character", the small one ain't bad, either!
    Bill Arnold
    Jul 2007
    DSM, IA
    5,719
    Thanks Bill!
    My Website
    30,017
    Nicely done, Jeff. Now see, if you didn't insist on turning everything so dang thin, and instead went thick like I always do, you wouldn't be having all this trouble with crack filling.
    Yorktown, Virginia
    5,015
    I like 'em both. I would try and wick/fill that crack with thin CA, followed by medium. Rub some finish on each side of the crack to limit the CA spreading and then a painters tape dam at the rim to hold the glue/grounds . Spot sand it, add another coat of DO, let 'er dry and bring on the popcorn!
    Jul 2007
    DSM, IA
    5,719
    Nicely done, Jeff. now see, if you didn't insist on turning everything so dang thin, and instead went thick like I always do, you wouldn't be having all this trouble with crack filling.
    My Website
    Jul 2007
    DSM, IA
    5,719
    Thanks Ted...That's pretty much what I did while turning the bowl...guess it can't hurt to try and do it again.
    My Website
    12,256
    Nice work Jeff i specifically like the size allows the wood to show well.
    Mar 2015
    Parker County, Texas
    1,500
    I have used several different kinds of filler, but never coffee grounds. Interesting. Gonna have to try that. But, nonetheless those are some nice looking bowls to me. I personally don't turn mine that thin. Makes them prone to all kinds of bad things. But, don't give up on the one bowl. Play with different things until you get what you want. Nothing wrong with developing a new technique!
    Create your own visual style... let it be unique for yourself and yet identifiable for others. Orson Welles
    Anytime spent learning something, no matter how trivial it seems, is not a waste of time.
    Aug 2008
    Reno, Nv
    3,632
    What's up with this?! I'm making thicker bowls than you??? Time to re-think my style! Very well done Jeff...finish is perfect!
  1. couple bowls
    Last Post: 09-12-2013, 04:29 AM
  2. Couple of Bowls
    By Jeff Bower in forum Lathe Project Showcase
    Last Post: 07-15-2013, 02:17 PM
  3. couple bowls
    Last Post: 09-28-2009, 09:59 PM
  4. A Couple of Bowls
    By Pete Jordan in forum Lathe Project Showcase
    Last Post: 04-16-2008, 12:46 AM
  5. A Couple of Bowls
    Last Post: 11-28-2007, 05:25 AM
