Results 1 to 5 of 5
Thread: Wardrobe shelves
    Field, Ontario, Canada
    113
    Wardrobe shelves
    Greeting y'all
    I'm planning to make some shelves in my son's wardrobe using 97"x12"x5/8" melamine and my SCMS.
    My question is does anyone have experience cutting dadoes in this stuff using only a thin kerf 100t blade on an SCMS? What was the process used? What was the end result? Would you do it again if you had to? Why or why not?
    Yann
    Anything that can go wrong will go wrong, so keep your hands away and watch out!
    yann, a router will give you much better results.....there`s a glue known as "roo-glue" that`s used to glue directly to melimine so no need for dados unless you just want dados?......tod
    113
    I understand a router or even a table saw with a dado set would give much better results but I don't have access to a 5/8" straight bit or a dado set for a TS.
    That glue you mention sounds like an interesting option.
    Or I'll just screw an 1/2" lip to the wall and let the shelves sit on that.
    I'm just looking for something at my skill level that looks nice.
    Yann
    Charlotte, NC
    1,487
    Yann, I am not sure how you would go about using a SCMS to cut dados??? I think your best bet would be to invest in a router. This is after all a great "new tool" justification. The blocks would work fine also. For a closet, that may be your best option.
    113
    Quote Originally Posted by Ed Nelson View Post
    By moving the board a 1\8" at a time and sliding the saw over
    Yann.
  1. Plastic Shoebox Shelves
    By glenn bradley in forum Shop Tours
    Last Post: 11-11-2012, 09:06 PM
  2. New Sake Fridge Shelves
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 06-21-2011, 10:24 AM
  3. Bathroom Shelves
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 12-31-2009, 06:56 AM
  4. Floating Shelves
    By Bob Spare in forum General Woodworking Q&A
    Last Post: 03-24-2007, 02:38 PM
  5. New Shelves from Reclaimed Maple Tree
    By Homer Faucett in forum Flatwork Project Showcase
    Last Post: 02-09-2007, 03:43 AM
