Results 1 to 5 of 5
Thread: How do I layout a radius to cut.
    I have some plans to build a BBQ cart and it calls for a 3 3/8" Radius and other ones such as a 5 1/4" radius. How do I do the layout for these? Does anyone know of a website that could help me.
    May 2011
    Cape Cod, Ma.
    1,553
    do you have a compass? if not, you will need one. using a ruler or tape measure open the compass to the desired radius. Using a square mark your center on the stock.
    looking at your picture above, say for the 3-3/8 radius, from your finshed line come down 3-3/8 and from the end come over 3-3/8. There is your center point. put the point of the compass on that center mark and draw your radius. do the same for each of your curves. Cut out your curves with a jig saw or band saw next to the line then sand to the line.
    Welcome to the family!!
    Nov 2012
    Wapakoneta, OH
    611
    If it isn't critical the radius be exactly as drawn (I'm guessing it's not from the layout)I usually look for household items that approximate the diameter I need, and use them to draw the arc. For example, a 5 gallon bucket I have is 10 1/4" across on the bottom. That would give you 5 1/8" for the large arc. A gallon of paint might do (don't have one handy to measure) for the 3 3/8. Lay out the start and stop points and set your pattern (whatever it is) to touch both and draw it out.
    Welcome, This may help:
    http://www.woodworkingtips.com/etips/etip110300sn.html
    I do have a compass but for non-critical things, do as Fred does.
    4,699
    If its a pain to use the compass because there isn't any material at the center of the circle I've laid it all out on stiff cardboard first and then cut along the lines with a razor knife and used the cutouts to transfer to the finished stock. This has the possible advantage of also giving you the option of more alignment points as well for the "on the stock" layout which sometimes matters.
    I do what Fred suggested a lot as well
  1. 1/4 Radius Bullnose Router Bit
    By Michael Tulak in forum General Woodworking Q&A
    Last Post: 11-08-2014, 12:42 AM
  2. radius question, math guru's
    Last Post: 12-15-2012, 10:05 PM
  3. Layout pen
    Last Post: 04-06-2011, 06:09 PM
  4. New shop Layout
    By Don Baer in forum Designs, Plans and Sketches
    Last Post: 04-27-2010, 03:31 AM
  5. Maximum Laminating Radius?
    By Brandon Campbell in forum General Woodworking Q&A
    Last Post: 07-17-2008, 03:57 PM
