Results 1 to 10 of 19
Thread: Nuthin' Fancy - But I'm Makin' Stuff
    Thomasville, GA
    6,000
    Along with doing a few updates to my SO2 cnc, I've actually been a little productive about making things. I've done some practice with engraving and v-bit lettering but need to work on that a bit more.
    One area of focus has been getting SketchUp and SketchUcam working together to make 3D. Below is an example of today's effort. I drew a small rosette in SU2015 (3.5" diameter), then kept playing with settings in SUcam until I got usable gcode. Don't fuss about the blue faces on the SU drawing - that's the way SUcam works - ask the developer! It turned out there were a couple of stray artifacts in the cut. If you look at the upper right corner, you'll see a small cut that shouldn't be there. SUcam added some lines of code that, in essence, dragged the bit along the face of the workpiece. After removing the erroneous code, a test trace using OPENscam was clean. I cut the rosette in mdf using a 1/16" ballnose bit and 20% stepover; next time a smaller stepover will reduce sanding. I haven't done any sanding on this sample piece.
ID:	90572 Click image for larger version.
    Another thing I have been working on for a while is a ZCI for my table saw. Sounds simple enough but the scaling wasn't right. Even after checking and re-checking the calibration of my SO2, the insert was too small. That's when I found out about which end is up with SUcam. Or, actually, which face it needs to reference - which is the blue face. Don't ask me - ask the developer. I posted the issue I was having on Phlat Forum along with graphics and that's when they told me the blue face has to be out, whether it's a 2.5D or 3D project. So, alrighty then, I turned blue, re-generated gcode and get perfect fitting ZCIs. The one on the right got a coat of poly from the remains of a rattle can.
    If the items below seem familiar, they are spindle mounts for my SO2. Yep, I made some with white HDPE a few weeks ago; they work but were a bit rough because of a brain freeze I had. Now that the spindle is spinning the right way, the bits cut much better!
    Anyway, just wanted you folks to know I haven't been totally lazy - except at times!
    Bill Arnold
    Very cool. Glad to see your getting stuff made.
    East Freeetown, Massachusetts
    3,022
    That's GREAT Bill,
    The rosettes are cool
    Southeast Pa
    2,019
    Way ahead of me already Bill.
    Saw some neat cheap software posted yesterday.. Can't find it now but will get back when I do. You are doing much better with your simple software than many that spend 00's if not 1000's. I really like your inserts...
    12,264
    Bill i think you have really shown just what is possible with your cnc. I honestly never thought that a cnc at its pricepoint would cut so well.
    Those latest spindle mountings are incredible. The finish of cut on the edges is remarkable.
    Can you mention if you recall just how long some of these items took to cut from the time you hit the go button.
    3,022
    Your ZCI reminded me of my Band saw inserts
Name:	Bandsaw insert-1.jpg
ID:	90584Click image for larger version.
Name:	Bandsaw insert-2.jpg
ID:	90585Click image for larger version.
Name:	Bandsaw insert-3.jpg
    Next time I will make them out of brass
    12,264
    Leo not wanting to hijack Bills thread but those bandsaw inserts do you not find that the holes cause small bits to get stuck and make a problem for ongoing sawing when cutting something that has small bits coming off? At first i was going to steal your idea of the holes because i can see it being handy to get rid of the sawdust but on second thoughts wonder about the jamming up.
    Thomasville, GA
    6,000
    Quote Originally Posted by Garry Foster View Post
    ... Saw some neat cheap software posted yesterday.. Can't find it now but will get back when I do. You are doing much better with your simple software than many that spend 00's if not 1000's. I really like your inserts...
    Cheap (free) software can be OK and the more I work with it, the more I learn.
    The ZCIs probably took about the same amount of time as using a pattern router, then drilling holes, etc. Much easier to stick a piece of mdf on the cnc and press GO.
    Bill Arnold
    Thomasville, GA
    6,000
    Quote Originally Posted by Leo Voisine View Post
    Your ZCI reminded me of my Band saw inserts ... Next time I will make them out of brass
    That's one of the next thing I need to tackle. I've bought a couple of replacement bandsaw inserts and haven't been satisfied. What bit and feed speed do you recommend for brass?
    Bill Arnold
    Thomasville, GA
    6,000
    ... Can you mention if you recall just how long some of these items took to cut from the time you hit the go button. ...
    I didn't log any of the times but, as I recall:
    a) the rosette took about 1.5 hours. I set the feed speed to 30ipm and could go faster next time - didn't want to press my luck with a 1/16" bit. For four 1/8" deep passes, the gcode is 97,800 lines.
    b) ZCIs took about 25 minutes to cut two of them. I set up the drawing to make two with a 1/8" two flute bit and feed rate of 20ipm. I could step up the feed rate without a problem, I think.
    c) spindle brackets took about 35 minutes at a feed rate of 30ipm with a 1/8" single flute bit.
    Bill Arnold
  1. Makin Dew...
    By Ken Cook in forum The Cook Shack
    Last Post: 09-19-2013, 03:47 PM
  2. Here's one for us CBG makers Makin' Sawdust Blues
    By Jay Caughron in forum Off Topic Discussion
    Last Post: 01-21-2013, 04:04 PM
  3. sharp and not fancy
    By Paul Gallian in forum Neander Tool Questions and Show & Tell
    Last Post: 11-08-2012, 08:08 PM
  4. Fancy or Firewood
    By Ryan Mooney in forum General Woodworking Q&A
    Last Post: 07-23-2012, 11:59 AM
  5. Restoration of Makin Waves
    By Jeff Horton in forum Flatwork Project Showcase
    Last Post: 01-21-2012, 02:51 AM
