Results 1 to 10 of 15
Thread: Another good use of bar clamps...
    13,453
    So my wheel barrel had sat with some left over concrete bags in it over the winter. The tire has always had a slow, slow leak on it, and I found it not only flat, but popped off it's rim this time. It's a tubeless tire, so in order to use it I had to get the tire seated back on the rim. Usually I'll pull the schrader valve and give it a quick blast of air while squeezing in on two sides of the tire, but that wasn't doing the trick this time. After about 20 minutes of trying this over and over I had just about resolved myself to removing the tire to work on it or just go get another as I had concrete that needed mixing.
    The over winter sitting had left the tire with a crease on one side and I simply didn't have enough hands to squeeze it in all directions and give it a blast of air at the same time. I got the idea to try this, and bam! it worked!
Name:	2015-05-30 16.13.58.jpg
    13,361
    Nice.
    What I've done in the past is to take a piece of rope, tie it around the tire, then put a stick under the rope and start twisting the stick around the rope to tighten the rope up all around the tire.
    And then there are the guys that spray a shot of starting fluid in the tire and lite it on fire.
    Yorktown, Virginia
    5,020
    I always use one of those ratchet strap tie downs.
    Feb 2012
    2,749
    Sheer genius! I've never had this problem, but when I do...
    Cheers,
    Roger
    4,699
    Good idea. I've been replacing all of my intermittent use tires with run flats cause I got sick of dealing with them. But still have a few left that ain't so may have to borrow this once those tools roll out.
    ...And then there are the guys that spray a shot of starting fluid in the tire and lite it on fire.
    Way to steal my suggestion, buddy!
    East Freeetown, Massachusetts
    3,022
    Great idea - something about those small tires - they all seem to leak.
    Jan 2011
    3,798
    That would be the 'Jed' method.....as in, Jed Clampett> the backwoods 'git r done' ingenuity
    5,322
    That's what I use, too. I have resorted to Brent's 'rope trick' once or twice, too.
    Jan 2009
    Carthage,Mo
    887
    I have also used my belt in place of rope. It is always handy and the belt buckle serves as comes long. Won't work if you have small waist.
    Just saying.
    David
  1. Jet clamps 50% off
    By Steve Southwood in forum Hot Deals
    Last Post: 06-16-2015, 02:17 PM
  2. Replies: 4
    Last Post: 04-10-2015, 02:38 AM
  3. So are these Clamps any good
    Last Post: 03-27-2014, 01:48 PM
  4. new clamps
    By Dan Noren in forum New Tools
    Last Post: 08-01-2011, 04:14 PM
  5. 4 way clamps
    By Syd Lorandeau in forum Old Ads
    Last Post: 11-28-2009, 10:07 PM
