Results 1 to 10 of 15
Thread: Oh! That new tool smell
    Feb 2012
    2,749
    The parcel post arived early today, but I waited until LOML was out of the way to open it without hearing the usual "How many tools/books/whatevers do we need in this house?"
    Threee Benjamin's Best bowl gouges, bought mainly for experimenting with different grinds. I am assuming that I'm looking at a traditional grind here, and that all I have to do to duplicate it is to match the bevel on my grindstone and rotate the tool. Right? I intend to keep two of them that way for now, and have one each of 3/8 and " to mess with.
    Oh, the bevels on the tools seem to be about 40 to 45. Would that be about average for a standard ground bowl gouge?
    Cheers,
    Roger
    Congrats on the new gouges.
    Regarding your grinding question...do you have a sharpening jig or are you grinding freehand?
    Aug 2008
    Reno, Nv
    3,632
    You're going to find the tempering on those a little less than quality. One session you may remove 1/16", the next time, 1/2". The Chinese have less than stellar quality control.
    Feb 2012
    2,749
    Vaughn, I'm using a jig. I have a platform made for skews and gouges, and a dealy for doing Irish grinds, thanks to Eddie Castellin, but my question is about standard grinds.
    Jim, I don't quite understand what you are telling me. I do know these aren't Sorbys though. These are ones I can afford to wreck while I'm learning.
    Cheers,
    Roger
    Tellico Plains, Tennessee
    4,353
    Roger,
    The only gouges I use are Benjamin's best...(most of my tools are BB or some other off brand) once sharpened properly, they work just was well as the more pricier gouges. I've tried a couple of Sorby's gouges and they didn't cut any better. The key is a consistent repeat of the sharpening angles. I use the wolverine rig to sharpen and just touch the tool to the grinder very lightly... as soon as I see the little sparks coming over the edge, I know I have a new edge and go back to work.
    Remember, it's not the tool that makes the man work, ... it's the man who makes the tool work.
    I'm not sure what the grind on my 5/8" gouge should be called... I have a 60 degree angle on the wings and cut all my bowls with it... I have a 1/2" at 45 degrees and I think the little one is a 3/8" at the same 45... they're almost too aggressive for my tastes, but I use them for some clean up and close work. I do almost every thing else with the 60 deg grind.
    I do have a set of 20 TPI thread chasers from Sorby... they work okay and would work better if I could slow my lathe down enough to do a better job of chasing threads. The set includes a recess too for relief at the bottom of inside threads... I use it to cut the groove inside my pepper mills for the wings on the crush grind grinders to fit into.
    Chuck
    Tellico Plains, TN
    Vaughn, I'm using a jig. I have a platform made for skews and gouges, and a dealy for doing Irish grinds, thanks to Eddie Castellin, but my question is about standard grinds...
    Hard to tell for sure from the photos, but I think you'll be able to match the grind on your new gouges with the Capt. Eddie jig. The length of the wings on an Irish grind (or fingernail, or Ellsworth, or whatever the kids are calling it these days) is largely dictated by how long you hold that part of the gouge on the grinder. If you spend less time grinding the sides than the tip, the wings won't be as long...more like how your new gouges look. Not positive it'd match, but it's pretty easy to check to see if the jig will be able to match the existing grind. With the grinder turned off, adjust the jig so the bevel at the tip of the gouge is sitting flat on the grindstone. Now rotate the gouge on the stone as if you were sharpening it, and see if the bevel is still sitting flat when you've got the gouge rolled all the way over to each side. If it doesn't match, try adjusting how much of the gouge is sticking out of the jig. You might start with 2" sticking out, but find that 1 3/4" works better to match the grind. Or 2 1/8...just experiment around and document what ends up working so you can remember it the next time.
    If you can't get the jig set up to match the current grind (or come very close), then you're into the realm of freehand sharpening using the tool rest. I haven't done much freehand sharpening at all, so I'll let someone else with more experience offer suggestions.
    BTW, I was very happy with the Benjamin's Best bowl gouges I used to own. They were great bang for the buck. They don't hold an edge as long as the Thompsons I use now, but they cut and handle well, and they are at a great spot on the price/performance curve. I never ran into any inconsistency in the steel like Jim mentioned, so hopefully his experience was a fluke.
    Aug 2008
    Reno, Nv
    3,632
    Easy guys...geez! Just passing on what hundreds of others have reported! I don't have Rogers budget for destructive testing on stuff I buy, so I have to research everything and get the best bang for my buck. Some people have never had a car accident...doesn't mean that someone else hasn't.
    11,834
    Might be going a bit off topic here. But, I have to agree. Some of my best tools are old garage sale finds. e.g. "cast steel" My most expensive tool, a large Taylor skew, gets dull between the grinder and the wood, I swear. Have an El Cheapo I picked up somewhere that vastly outperforms it.
    4,702
    Quote Originally Posted by Jim Burr View Post
    Heh, well I'll add a +1 to "they aren't all that bad" list If you do want to do some destructive testing then doing it on $20 tools is for sure the way to go and is primarily the reason I started out with the BBs since I had no idea .
    Now that I know more about what I like with at least my bowl gouge, I'm pleased to have upgraded it to a Thompson, but don't mind having some cheaper tools to play with and not be all that upset about loosing a little metal.
    I'm not doubting at all what you reported, bud. Just saying I hadn't seen it in the BB gouges I once owned.
    Price isn't the arbiter of quality, for sure. Thompson tools, which are the best I've ever used, and not the most expensive. And they cut no differently than a Harbor Frieght cheapie...they just stay sharp a lot longer. (And although I'm happy with the ones I own, I wouldn't consider Taylor a benchmark for expensive tools.)
  1. I love the smell of beeswax...
    By Art Mulder in forum Flatwork Project Showcase
    Last Post: 11-26-2012, 09:04 PM
  2. You can almost smell the rubber burning
    Last Post: 07-17-2011, 08:16 PM
  3. Smell the roses
    Last Post: 06-27-2011, 04:43 PM
  4. Stopping to smell the....sunset.
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 09-07-2008, 12:57 AM
  5. I SMELL A GLOAT IN THE AIR!!
    By Bruce Shiverdecker in forum Turning Tool Questions and Show & Tell
    Last Post: 01-30-2007, 04:56 AM
