Results 1 to 10 of 10
Thread: CN glue dry time?
    Feb 2012
    2,746
    CN glue dry time?
    I have two corner joints in MDF or similar material to join. If I use fast drying cyanoacrylate glue, and don't have a good means of clamping it, how much older will I get holding with my fingers until it dries?
    Cheers,
    Roger
    Feb 2012
    2,746
    It's a butt joint. Of course it's a butt joint, I made it.
    Cheers,
    Roger
    4,698
    Not sure on the dry time, it's pretty fast with quick cure though so probably about when you get task tired of holding it it ought to be getting pretty close. Most CA cures based on moisture so that will affect it some and you can affect the humidity of the joint (you don't want it wet cause that makes it brittle but more humid is faster).
    Also remember that most CA is brittle and gets more so over time, so consider that for your use case.
    868
    If you had glued it when you first posted this thread, it would be dry now!
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    Feb 2012
    2,746
    I decided to go for some lunch first, then realized I could hold the pieces in place with painter's tape, which is what I did, as well as nailing the piece in place with my handy electric brad nailer. Looks OK. LOML will be marginally happy.
    Cheers,
    Roger
    4,698
    So ends up about as good as you can possibly hope for then.
    30,008
    You're on a roll, Roger.
    11,825
    CN? Dunno wat that is. Oh, CA! Some dries very quickly. But, really for application you mentioned, wrong stuff, IMHO.
    Mar 2010
    SW MN
    34
    Get yourself some ca glue accelerator--------apply ca---align parts---spray accelerator---done. Works for me
    Feb 2012
    2,746
    I had lots of time. so I just let it dry. Is OK.
    Cheers,
    Roger
  2. Long time lurker first time member
    By James may in forum Welcome and Introductions
    Last Post: 01-29-2016, 06:36 AM
  3. It's time for a Shed Thread -Time to get the roof on
    Last Post: 10-27-2011, 02:26 AM
  4. Glue Open Time
    By Tom Blank in forum General Woodworking Q&A
    Last Post: 07-15-2011, 07:45 PM
  5. How much time to dry glue?
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 01-29-2009, 12:56 AM
