Results 1 to 10 of 23
Thread: Dead On, Totally Repeatable TS Sled
    May 2010
    Orland Park, Illinois, USA
    278
ID:	90733 Click image for larger version.
ID:	90734 Click image for larger version.
ID:	90735Click image for larger version.
ID:	90736 Click image for larger version.
ID:	90737 Click image for larger version.
    Construction:
    * 1/2” ply base
    * 1/4” ply top
    * 1 1/4” poplar fences
    * Incra T-track and T-track plus
    * Incra precision racks and tape measure (have to add a right to left one and the final extension one on the right); allows for totally accurate and repeatable stop settings to 1/32”.
    * T-bolts and over sized holes to allow for fence adjustment with adjusting bolt (far right in second pic)
    * replaceable zero clearance inserts
    * walnut and MDF flip up stop block with 5/16” plastic bolts for clamping
    * two coats of poly on the bottom, then fully waxed
    * delrin miter bars, no slop, no seasonal movement
    * 36” long and will crosscut boards up to 18” wide
    Used the 5-cut method to adjust the fence and am .001” to .002” off in 15”. I’ll call this Dead On.
    Thanks for looking.
    Yorktown, Virginia
    5,014
    Nice! You put a lot of thought into that puppy. I really like the replaceable inserts. Looks heavy.
    May 2010
    278
    Ted, it weighs in at 22#'s so quite manageable.
    13,360
    Very well built. Looks really nice.
    The only suggestion I might have would be to put a guard of some sort where the blade comes through the fence.
    Really like the stop and the replaceable inserts.
    May 2010
    278
    Brent, the guard is coming. I did not/will not forget it. Thanks for the reminder though.
    13,360
    4,698
    +1 Nice design. The incra stuff is pretty swell as well.
    Now to add an angle cutting system to it
    30,014
    Very nice, Robert. The Incra stuff really adds a lot. Love my Incra tools.
    May 2010
    278
    Brent ... yep, the guard is in place: Click image for larger version.
ID:	90747 Click image for larger version.
    Ryan ... the miter (angle cut) fences are coming soon.
    Slots in base are for T-bolt secured clamps and function well: Click image for larger version.
    And a tease for what is up next: the Incra racks for positioning the stop block make this very doable and repeatable
ID:	90750 Click image for larger version.
    Think "outside the box" but more on this when the project gets started.
    Thanks to all for looking.
    13,360
    Dang, Now you are making me want to redo mine!
  1. I brought her home and my wife was totally cool with it
    By Mohammad Madha in forum Turning Tool Questions and Show & Tell
    Last Post: 02-16-2011, 01:50 AM
  2. NWA/Totally Turning Display
    By Don Orr in forum Lathe Project Showcase
    Last Post: 04-02-2009, 03:57 PM
  3. totally stupefied in Arkansas
    Last Post: 01-07-2007, 04:35 PM
Tags for this Thread
