Results 1 to 8 of 8
Thread: Unique Red Cedar Display Bowl
    Mar 2015
    Parker County, Texas
    1,493
    I turned two of the today, and that they are so similar I'll only post one. Any of the usual minor cracking was sealed with good ol' superglue. This was turned end grain so I could have the upper edge that I wanted. I've already had several inquiries so I don't think they will last very long, which will in turn make me turn more of them. I carried the outside sweep pretty much to the lip edge though it probably doesn't look like it because of all the gaps the wood has. But, I do love the rustic look of it. The bowl has an average diameter of 12 1/2" with a height of 4 1/2" and a depth of 3". It's a little thicker on the bottom but it's quite acceptable. A little bit of extra weight on the butt of the bowl never hurt anybody that I know of. I first sealed the wood with walnut oil, which as the wood is so dry it soaked in 3 coats before I could do anything else. Then I got several coats of a walnut oil/shellac mixture while spinning, so I can't really say for sure how many coats it got. Probably 5. Maybe less. I just go until the finish starts feeling kinda tacky and makes the brush drag. Thanks for looking.
    4,698
    Nice!
    I think the little flare out on the lip of the edge helps highlight the natural edge. Keeping a few remnants of the outside of the tree down the edge helps that as well.
    How thick is the base? I've had somewhat mixed luck with bowls with the pith in the bottom surviving long term (no cedar though) and the survival rate seemed somewhat correlated with being thinner. In most cases the cracks were accepted as "character" and I moved on unless it was to bad
    Mar 2015
    1,493
    Hi Ryan! Thanks for the comments. The base is a bit over 1" in total thickness. The center of the base foot is beveled so in the center it might be a little less. I normally get the depth where there is only about 3/4" of thickness on the base. I do like a somewhat broad and heavy base on my bowls. Yep. Cracks are character and I a lot of times just let some superglue drip down in them to strengthen the wood and not worry about any dust filler or whatever.
    30,008
    Very cool. I don't think that will be in your inventory for long.
    4,698
    Quote Originally Posted by Dave Hoskins View Post
    I see a lot of folks who like the character, and in some cases like this bowl I don't think they'd detract at all Being a type A personality they bug the heck out of me on my work but I've been learning to deal.
    Aug 2008
    Reno, Nv
    3,632
    That's a big 'un and the finish is great! Something about the foot strikes me a little odd...ehhh...wadda I know!
    Tellico Plains, Tennessee
    4,351
    That is definitely some beautiful & crazy color in that... like Vaughn said, enjoy it while you can, don't think you'll get to keep it long.
    Chuck
    Tellico Plains, TN
    Mar 2015
    1,493
    Thanks! Appreciate the comments. Jim, the foot might strike you a bit odd because it is thicker than I usually do. Just one of those things that you discover when you are done and just go with it.
  1. Mountain Cedar Display Bowl
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 05-27-2015, 09:03 PM
  2. Unique Bodark Bowl
    Last Post: 03-27-2015, 09:41 PM
  3. Cedar Bowl
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 01-07-2012, 03:11 AM
  4. Cedar Bowl
    Last Post: 12-03-2011, 04:23 AM
  5. Cedar display shelf
    By Kevin Vernon in forum Flatwork Project Showcase
    Last Post: 10-07-2009, 06:49 PM
