Results 1 to 10 of 14
Thread: I learned Something New
    Independence, Kentucky
    1,355
    I guess we are never too old to learn, I ran across this today and discovered that I have been installing these inserts wrong for a long time. How many of you knew this and never bothered to tell me?? I tried using the slots to install them with a screw driver, and could never get it why one of the ears would break off
    After seeing this it does make a lot of sense.
    East Freeetown, Massachusetts
    3,022
    Wonder why the manufacturer didn't come up with an installation tool to sell to us?
    3,022
    well apparently they do.
    You can use the slotted installation or the bolt installation. Either is OK and correct. The Manufacturer also sells an installation tool to drive via the slot.
    Many ways to skin a cat.
    4,701
    Heh, figured that out last year. Never had any luck driving them into harder woods and sort of half figured it out on my own out of frustration and then say someone explain that the slot helps cut the thread which was a real moment for me as well
    The other thing I found with these is that there are two kinds of outside threads, one is coarser and has a sharper edge the other is more like a machine screw thread. The coarser one has proven much easier to drive and less likely to split the wood. Of coarse the other one is what seems to be easier to find..
    13,364
    When the drill press doesn't work, I use a home made installation tool. Use it with a ratchet wrench and it works fine.
    S E Washington State
    3,777
    Well, well, live and learn... Thanks.
    "We the People ......"
    12,264
    Well now i am confused and just in time too. As i wish to use these brass inserts in fixing my coffin plane sole.
    Just yesterday i picked up one of these tools from Lee Valley supposedly specially for the job of installing inserts and it uses that slot to drive them home.
    http://www.leevalley.com/en/wood/pag...at=1,180,42334
    So who is correct?
    9,077
    I just use a cut off bolt with a couple nuts doubled up against a washer and the DP as shown. Runs 'em in true every time. I guess we were all keepin' it a secret from you Charles . . . you know . . . power trip
    13,364
    So who is correct?
    I'm voting everyone. There's more than one way to shave that squirrel.
    1,355
    I have to agree, there isn't a right or wrong way, I have one of those thingies also Glenn that I use.
  1. I learned something new today.
    By Karl Brogger in forum General Woodworking Q&A
    Last Post: 02-25-2015, 06:31 PM
  2. Lesson learned, I think...
    By Roger Tulk in forum General Woodworking Q&A
    Last Post: 05-06-2012, 07:33 PM
  3. I learned something today
    By Julio Navarro in forum General Woodworking Q&A
    Last Post: 01-21-2012, 01:58 PM
  4. What I have learned
    Last Post: 05-01-2010, 05:25 PM
