Results 1 to 10 of 13
Thread: Pine bowl
    Feb 2012
    2,746
    Pine bowl
    This is the bowl I told you about yesterday. It is about 8" in diameter, and 1.6" deep.
ID:	90807Click image for larger version.
ID:	90808Click image for larger version.
    Cheers,
    Roger
    Feb 2012
    2,746
    I submitted this in a hurry as my computer has been shutting down without warning. I may have to send it to the big computer room in the sky. The bowl is kiln dried pine with a couple of coates of Minwax finishing wax. You'll get tired of looking at these soon. I inted to get a lot of practice!
    Cheers,
    Roger
    Feb 2012
    2,746
    The black marks in some of the grain go right through to the other side. I thought they were just dirt, but I guess they're natural.
    Cheers,
    Roger
    30,008
    Nicely done, Roger. Pine (especially dried pine) is a tough wood cut cleanly. (That's why you had some spots of tearout.) I also see a few marks on the inside that indicate the wood was bruised by the heel of the gouge, but things like that will improve with practice. You're off to a great start!
    4,698
    Yeah that's pretty nice for pine, its a real pain to get a decent cut on (I know folks do it and my hat is off to them!).
    I get those, the 80 grit gouge sometimes helps a little there
    Mar 2015
    Parker County, Texas
    1,491
    I'm glad to see someone get something good from pine. I never had any luck with it. It might be the species of pine I got a hold of as well. It's some kind called afghan pine. Really bad wood for turning. Literally falls apart on you. Oh, well. Good going, Roger!
    Feb 2012
    2,746
    This is white pine, kiln dried. I've heard Afghan pine can just explode off the lathe without warning.
    Cheers,
    Roger
    Feb 2012
    2,746
    If I put a secondaty bevel on the back of the gouge, would that help? I can do that easily.
    Cheers,
    Roger
    4,698
    Helps for me, I actually use a weird grind because ain't no one smacked me around to make me know better... but it basically has almost no heal. The bevel you ride only needs to be a small fraction of an inch long for it to work, the rest is (imho) mostly in the way.
    30,008
    Yeppers, the secondary bevel can prevent the bruising. Instead of just a single, second bevel, I kind of round off the heel by putting a whole bunch of beveled grinds on it.
    And ditto what Ryan said about the 80 grit gouge. Sandpaper is just another tool in the box, in my opinion. That said, sometimes the bruise can be tough to sand out. And it also took me a long time to learn (the stubborn way) that using a lot of pressure on the sandpaper doesn't really help. Instead, it heats up the wood and can sort of case harden it, making it that much harder to get rid of the blemishes.
  1. First Pine
    By Tom Wallace in forum Finishing School
    Last Post: 05-22-2015, 07:52 PM
  2. Ponderosa Pine bowl
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 12-17-2009, 05:44 PM
  3. matching salvaged pine flooring to existing pumpkin pine floor
    By Robert Gilmore in forum Finishing School
    Last Post: 02-23-2008, 09:45 AM
  4. A Little Pine Box
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 11-10-2007, 10:56 PM
  5. A Pine Box
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 06-03-2007, 03:45 PM
