Results 1 to 10 of 12
Thread: Something Different-Pecan Root Burl
    Mar 2015
    Parker County, Texas
    1,493
    Finished with hauling the wood from a pecan tree yesterday and managed to bring to the log yard a fairly big pecan root burl. The wood part is about 36" in diameter. I took 3 of the photos with it sitting chained to the bucket of the tractor which is a 40 hp. for size reference. Not sure what all I will get out of it when I start cutting into it, but it should be some pretty good looking stuff. Hope so, anyway. With the ground still wet from the rains where this was loaded it was a good trick to pull off, as the tractor kept wanting to slip and slide around a bit. But, eventually hardheadedness won out and it went on the trailer. Just thought you guys and gals might get a kick out of the photos. Yes, the log by the tractor is part of the trunk of that pecan tree.
    30,008
    That's a passel of pecancrete, for sure!
    Jun 2007
    4,944
    Pecan is a beautiful (though tool dulling) wood and you have a "passel" of pecan to play with.
    Enjoy it,
    JimB
    VOTING MEMBER
    Mar 2015
    1,493
    Yes, guys it is a fair amount of wood. But, in all honesty, it will not last me that long. Now I know that pecan is not a soft wood, but why is it a tool dulling wood??? I quite enjoy turning it. It certainly is no where near as hard as bodark. Or, mesquite for that matter. Well, maybe I am just weird. But I find it quite enjoyable to turn.
    Yorktown, Virginia
    5,009
    You said it, Dave. It's all relative. I've turned much harder wood. Pecan is a favorite.
    Aug 2008
    Reno, Nv
    3,632
    I see a gazillion M&M holders in your future...or a quadbazillion pens!
    Mar 2015
    1,493
    Absolutely, Ted! Jim, seeing me no do pens, it's definitely gotta be M&M holders!!!
    Tellico Plains, Tennessee
    4,351
    Looking forward to seeing your M&M savers.... Love pecan to turn.... it can be hard, but agree that Bodark is harder.
    I had a couple of pecan logs about 3' long that a neighbor gave me... let them sit a year and then turned bowls... half the bowl is light colored and half is a darker brown... I didn't dry properly, so I did have some checks in them, but with enough CA, not a problem... nice heavy bowls.
ID:	90894Click image for larger version.
ID:	90895Click image for larger version.
ID:	90896Click image for larger version.
ID:	90897Click image for larger version.
ID:	90898Click image for larger version.
    The first two were done early while the wood was still green... I used my wood saver to core them from same blank.
    Chuck
    Tellico Plains, TN
    Mar 2015
    1,493
    Nice bowls, Chuck. I rough out my pieces while the wood is a green as I can. Then I give each one a bath in denatured alcohol and then put it in my kiln to dry. The DNA is supposed to help it dry more evenly. I have my kiln running at about 90. If I start to get it fuller than it is, then I can turn it up a bit as needed. Doing that seems to minimize the checking for me. My kiln is homemade and heated by brood lamps. If I need it hotter I just turn on more lamps. I have six total in it but right now with only 4 blanks in it have 3 burning. I'm going to build a better one probably this fall, though. This poor thing has been moved too many times and it really wasn't built to move. Oh, well. Another project.
    30,008
    I agree there are harder woods out there, but I've had one or two wrasslin' matches making hollow forms with fairly dry pecan. Here's one of them, overweight finial and all...
Name:	HF051 - 02 800.jpg
    Like you, I try to turn when the wood is as green as possible, but sometimes it's not all that possible.
  1. Pecan Burl Bowl
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 04-08-2016, 12:15 AM
  2. Oak root HF
    Last Post: 11-08-2010, 11:00 AM
  3. oak root BH
    Last Post: 11-03-2010, 10:40 PM
  4. Ash Root Bowl
    Last Post: 04-29-2008, 02:01 PM
  5. Replies: 12
    Last Post: 04-07-2008, 04:33 PM
