Results 1 to 3 of 3
Thread: TS Sled Stop Blocks
    May 2010
    Orland Park, Illinois, USA
    278
    TS Sled Stop Blocks
    Not wanting to allow the saw blade to exit the sled, I made these. They lock into the miter slots on the extension table. They are easy to use, quick to install, removable and can be stored with the sled. Thanks for looking.
ID:	90889 Click image for larger version.
ID:	90890 Click image for larger version.
ID:	90891 Click image for larger version.
    Jan 2015
    Spring Hill Kansas
    16
    You should drill a hole in the slot so your sled will push out any sawdust from the slot. That way you wont have a build-up of dust to keep the sled from going all the way to the stops.
    3,134
    I don't have a regular out feed table instead I have my bench behind the TS.
    I also have a router table for the left wing of the TS. So I made the sled so it overhangs the left wing/router table edge & put a small block on the bottom of the sled & a small block on the outboard edge of the router table when these block contact each other it stops the sled.
  1. Grr-rrip blocks $4.00, get 'em while they last
    By fred hargis in forum Hot Deals
    Last Post: 01-12-2015, 04:23 PM
  2. Band saw riser blocks
    By Chuck Ellis in forum Turning Tool Questions and Show & Tell
    Last Post: 02-19-2009, 01:18 AM
  3. Sanding blocks
    Last Post: 12-08-2007, 04:28 PM
  4. Bessey 2440 Kit, includes blocks
    By ken werner in forum Hot Deals
    Last Post: 02-12-2007, 06:55 PM
  5. Fence stop blocks
    Last Post: 01-16-2007, 12:47 AM
Tags for this Thread
