Results 1 to 10 of 15
Thread: Live video while turning - interesting ideas
    4,698
    Some interesting ideas here, you could build a "better than the laser pointer" setup for a hollowing rig for pretty cheap nowadays and some of the other ideas were pretty neat as well.
    edit: for some reason its not embedding the video, just showing the link.. oh well.
    Mar 2015
    Parker County, Texas
    1,497
    Interesting goings on there, Ryan. A bit hi tech for me, but still interesting. I do like the way he made it easier for her to see doing the fine detail work. Interesting, Thanks!
    Yorktown, Virginia
    5,014
    Good find, Ryan. This helped me understand the mechanics behind some of the commercially available hollowing systems. As you said, it should be pretty easy to set up a replacement for the laser pointer that works even better.
    S E Washington State
    3,777
    That is some cool stuff. Be as much of a hobby playing with the cameras and computers as the wood working hobby you are using it on. Yep to high tech for this old guy, but sure looks like fun.
    "We the People ......"
    30,014
    My only issue with the camera as a replacement for the laser is the fact that the border overlay would need to be adjusted (or re-done) every time you change the angle of the cutting tip in relation to the boring bar. In the course of making the average hollow form, that angle is adjusted a number of times. (Or at least it is on my lathe.) Adjusting the laser is fast and simple. I'm not sure if adjusting the overlay would be as straightforward.
    4,698
    Good point Vaughn, it looked fairly quick to redraw with the tooling he had, but certainly slower than moving a pointer.
    I think the plastic overlay on the screen looks like it's probably competitive since you ought to be able to just rotate and restick it if you're using the right material for that.
    The one thing I did like about it is that it's pretty easy to see the offset for the wall thickness, and you can see the cutters approach clearly "through" the wall. It seems that that might be a useful learning tool even if you went another way later for production.
    13,360
    Certainly an opportunity for a custom turning app to be created that could be adjusted quickly.
    30,014
    ...and you can see the cutters approach clearly "through" the wall. It seems that that might be a useful learning tool even if you went another way later for production.
    Very true. Seeing the relation between the cutter and the wall, particularly the angle of the cutter, would be very useful.
    Phoenix, AZ
    112
    I've seen both Trent Bocsh's Visualizer and the Cuttervision video hollowing systems and both can change the image of the cutter faster than I can re adjust my laser. Both are very expensive though. Trent's uses a grease pencil on a heavy plastic overlay of the monitor, the Cuttervision shoots a video still image of the cutter head and you can add a red outline the width of your choice through the software. Both very slick. After seeing these demo'd, I tried to find iPhone/Ipad software to try what this guy does in his video but had no luck. Guess I'll wait for his future videos.
    4,698
    Yeah, he said he was using mostly free software but I haven't figured out what he's using either.
  1. How to dry live edge?
    By David Agnew in forum General Woodworking Q&A
    Last Post: 03-19-2015, 02:20 AM
  2. Cool live video
    By Jim Burr in forum General Woodturning Q&A
    Last Post: 11-29-2012, 06:16 AM
  3. Turning a winged box video... Gwinett Woodworkers
    By Ned Bulken in forum General Woodturning Q&A
    Last Post: 10-11-2012, 06:16 PM
  4. Interesting Video
    Last Post: 01-07-2011, 05:33 PM
  5. Cool Turning Video
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 11-18-2010, 11:34 PM
