Results 1 to 10 of 11
Thread: Info for Dan Noren (and anyone else who wants to read)
    Thomasville, GA
    5,987
    Dan,
    Your message was on our answering machine after our power was restored this evening. We had some serious storms in the area and lost power shortly after you called. Anyway, on with it.
    The bit I used is a single-flute 1/8". The other parameters are in the header of the gcode file as seen below.
    (Generated by SketchUcam V1.3)
    (File: CNC_SpindleBracket.skp)
    (Bit diameter: 1/8")
    (Feed rate: 30"/min)
    (Plunge Feed rate: 5"/min)
    (Material Thickness: 1/2")
    (Material length: 3 1/4" X width: 5 3/4")
    (Overhead Gantry: true)
    (Multipass enabled, Depth = 1/16")
    This is from the gcode for cutting one bracket. It's the same in the file for two brackets. At the 30ipm feed rate, I got good chips and no burning.
    One thing to check if you haven't already is which way your spindle is rotating. I've mentioned this before, but when wiring according to the published instructions my spindle was spinning the bit clockwise. I didn't catch that at first. Obviously, it makes a big difference between melting the plastic and cutting cleanly.
    Bill Arnold
    Dec 2008
    falcon heights, minnesota
    5,605
    now is that clockwise looking from the top of the spindle (silly question i know, but needed to ask, just the way my day has been going)?
    benedictione omnes bene
    www.burroviejowoodworking.com
    Thomasville, GA
    5,987
    Quote Originally Posted by Dan Noren View Post
    The correct direction will be clockwise viewing the top of the spindle. That means the bit is being spun counter-clockwise which is correct for a router bit.
    Bill Arnold
    Dec 2008
    5,605
    So an up spiral is just the opposite of a normal drill bit?
    Thomasville, GA
    5,987
    No. Both should spin counter-clockwise if you're looking at the bit itself.
    Bill Arnold
    Dec 2008
    5,605
    So I should cross the wires to the spindle so that it spins counterclockwise?
    Thomasville, GA
    5,987
    What direction is your spindle spinning when you look at the top now?
    Bill Arnold
    Dec 2008
    5,605
    Looking at it from the top, it is spinning clockwise.
    Thomasville, GA
    5,987
    Then you should be good to go. The spindle speed I set is 5000rpm. You can see that near the gcode header on the line "M3 S5000". If you're using the variable spindle speed module, it should read that speed.
    The bit I used can be seen here on ebay.
    Bill Arnold
    Dec 2008
    5,605
    i was using my last 2 flute bit when i tried to cut the brackets. hard to tell what the speed is with the manual control. just the knob to turn it up and down.
  1. BOLO Dan Noren
    By Bill Arnold in forum Programming, Troubleshooting, and Q&A
    Last Post: 09-04-2015, 09:02 PM
  2. Thank you Dan Noren!
    Last Post: 09-25-2014, 06:00 AM
  3. Happy Birthday Dan Noren!
    Last Post: 06-21-2013, 03:55 AM
  4. test for Dan Noren
    By Frank Fusco in forum Site Questions and Test Posts
    Last Post: 07-28-2009, 01:18 PM
