Results 1 to 10 of 18
Thread: anyone know anything about cements, bricks?
    new york city burbs
    10,188
    I stepped up onto the brick step up near my front door and the front row of bricks has separated and can be pulled forward.
    Its not all of them just one side of the stoop.
    There is cement underneath them, obviously the rough winters, ice, rain, have killed the bond between that cement and brick.
    (it was installed in 2003)
    Can someone suggest a product, one of those concrete patch, mixes, ? that I can mix easy enough and just try to secure the bricks in enough so they wont pull out.
    A product readily available at home depot or lowes.
    Human Test Dummy
    30,017
    OK, I'll preface this by saying I'm the son of a civil engineer who made a living designing concrete mixes (among other things).
    It ain't cement. It's mortar. Cement is the gray powder that you mix with sand and gravel to get concrete, or just sand to get mortar. My dad beat that into me (figuratively) as a young child. I got in trouble in 1st grade for correcting my teacher when she talked about a "cement sidewalk". There ain't no such thing, lol.
    Anyway, back to the question...
    You should be able to fix the loose brick with fast-setting mortar repair mix available from Home Depot or Lowe's. If you use it, you should knock off as much of the old existing mortar on the sides and bottom of the loose chunk as you can. You'd essentially be replacing the old mortar with new. I'll warn you in advance that doing neat mortar work is harder than it looks. The pros make it look easy.
    http://www.lowes.com/pd_354681-286-1...ductId=3472653
    For the spots where you just have gaps in the mortar, but the bricks aren't yet loose, there's not much (short of expensive epoxy products) that will flow into the crack to hold the pieces together. You can try to mash some fresh mortar into the cracks, but it will not do much to help adhere the two parts together.
    you could also use a product called thinset. it is used for setting tiles but reading the manufacturers specs it will also work to adhere bricks to existing concrete and mortar.
    I don't kn ow about lowes but the orange borg carries it.
    http://www.homedepot.com/p/Custom-Bu...SW50/100091767
    new york city burbs
    10,188
    before I start tomorrow in the garage, Im heading over to HD to see what they have in stock.
    I have a lot of trowels, all shapes and sizes, so 15 bucks for a bag of mortar repair is worth the investment.
    if I see my work doesn't hold, Ill get a brick guy to take off the front bricks and do it over again, or whatever he can remedy.
    Ill see how I do first, as I don't think its too bad, the mortar underneath is very solild and bricks don't seem to be going down or falling off.
    Human Test Dummy
    13,361
    I do know that stuff is heavy as all get out.
    new york city burbs
    10,188
    I was watering some flowers getting about to head over to hd this morning, I was talking to my neighbor, the ex contractor(he works if he feels like it), I showed him the bricks, told him Im going to get a bag of mortar repair, and he offered me a tube of construction adhesive, says hes used it on bricks before, and had some in his shed.
    I had to borrow his 29 ounce gun, I only have a small tube gun, and after making a mess on one brick, Ill see how it works before I get mortar repair.
    didn't cost me anything, Ill see if it sets.(I used a lot, after I cleaned out all the old mortar/cement, I wanted to fill any small gaps so I used half a tube and also glued side of bricks together)
    Human Test Dummy
    13,448
    It will probably hold, but it doesn't repair the cracks that the water is getting into and freezing that caused them to pop loose in the first place. You'd be better off with Vaughn's advice in the long run as the joints will get re-sealed to keep it from occurring in the future or water from getting in and breaking down the structure under it. Just my $.02...
    If you've already done it, they do sell a crack repair filler (http://www.homedepot.com/p/Quikrete-...4000/100318507) that you can pour in the surrounding cracks to fill them. I'd get a chip brush and some sand to pour over it as you put it in. Sprinkling some sand then brushing the joint can help color match the fill to mortar that is already there.
    new york city burbs
    10,188
    the stoop sunk around 3/4 of an inch this past winter.
    I looked around and it seems the entire border is a bit compromised, but only those bricks were loose.
    Its only a matter of time.
    any repair I do will be a temporary one, (that's what the contractor told me today), Ill wait until it all comes apart then have it rebuilt.
    Human Test Dummy
    5,321
    Same thing has happened to my front stoop, Allen. Loose/crumbling bricks and mortar. Lotsa loose bricks in the sidewalks, too. The past (record breaking cold!) winter was pretty brutal. Had frost heave where there'd never been any before.
    Got an estimate, and the guy wanted about $2,000 to re-do just the stoop and front walk, and when he described the shoddy work he wanted to do (just pour a couple inches of concrete over the whole thing), I sent him packing. I need to find another contractor, or else try to take on the whole job myself. Not really something I want to try.
    new york city burbs
    10,188
    I wouldn't attempt to do it, but Id get the same guy that did it originally.
    He was highly recommended.
    Human Test Dummy
