Results 1 to 5 of 5
Thread: Best Place to Get Hoses /Fittings Etc.
    Jun 2012
    Laurinburg NC
    316
    I am going to get the HF 2hp dust collector.I see it takes 4" hose and I will need a couple of gates to shut off air flow in 2 lines.Where is best place to get the 4" hose and blast gates.............Harbor Freight??
    Are the hoses and blast gates at Harbor Freight any good? I see some people say they dont fit.
    I guess the only place to get the Wynn filter is at Wynn http://wynnenv.com/products-page/woo...filter-pricing.
    I have plastic and metal blast gates. All have been in use for a decade or so. The metal ones stick a bit sometimes. I rigged magnets to keep them open of shut as opposed to the threaded knobs intended for such.
Name:	blast gate magnet 001.jpg
ID:	90978Click image for larger version.
Name:	blast gate magnet 002.jpg
ID:	90979Click image for larger version.
Name:	blast gate magnet 003.jpg
ID:	90980Click image for larger version.
Name:	blast gate magnet 004.jpg
    I sanded the end to expose the corners on the plastic ones to avoid the sawdust getting jammed in them.
Name:	blast gate anti clog (1).jpg
ID:	90982Click image for larger version.
Name:	blast gate anti clog (2).jpg
    I have found I prefer the clear hose from Rockler or Woodcraft (whichever one has it on sale at the time) as shown in the pics above. The super flexible hose tries to gather up and pulls at you, the higher quality hose can be too stiff for some purposes.
    30,008
    When I bought my DC I also bought the "starter pack" of hose and fittings from Harbor Freight. The flex hose was stiff and a pain to move from one machine to another. The hose clamps were low-quality wire ones. They worked OK, but just barely. I eventually bought a better quality hose and some Y fittings from Rockler. I also got some plastic gates. (Don't remember if they were part of the HF kit or if I got them elsewhere.) For a while I had lines running to various tools, and I used the gates to control what machine was getting suction. Eventually, I got tired of having the extra hose on the ground all the time, so I just went to a single 20' hose that I moved from one machine to another. (Quick-connect fitting on the end of the hose.) Moving the hose was as easier and faster as closing and opening gates.
    5,167
    Been a long time since I built a system. I can see where I will have a lot to learn! FWIW, I bought the items in question from Grizzly and felt they were fine. Gives you another place to shop.
    Nov 2012
    Wapakoneta, OH
    611
    I just bought some more hose from Woodworker's supply, the clear stuff (2 proce ranges, I got the cheaper one). It came yesterday and I'm loving it. While it is heavy (weight-wise) it is so flexible it was packed in a 3' long box lengthwise. Anyway, back to the fitting thing: my first rule of DC: nothing will fit perfectly. That seems to have been the case with everything I've tried so far, and making it fit really isn't hard....but sometimes it isn't very pretty.
  1. Replacing washing machine hoses is it a scam ?
    Last Post: 02-06-2016, 03:21 PM
  2. This Place
    Last Post: 09-27-2011, 11:04 PM
  3. I really like looking around in this place
    By Dave Hawksford in forum General Woodworking Q&A
    Last Post: 03-26-2011, 03:38 PM
  4. I don't know if this is right place for this but
    By Chuck Ellis in forum General Woodturning Q&A
    Last Post: 12-01-2009, 02:58 PM
