Results 1 to 10 of 19
Thread: How'd I do?
    Honolulu, Hawaii
    1,103
    How'd I do?
    Hi friends,
    I just picked up a neat little lathe from Craigslist here in Honolulu. It's an older Taiwan made 6" variable speed machine but it's in real decent shape. The seller couldn't find the tailstock but they're still looking. It did come with a bunch of stuff though,
    like:
    the lathe as shown in the ad,
    the lathe as I received it today,
    some of the things that came with it,
    2 - 3" universal chucks (both new) & a set of tools made by Crown Tools of Sheffield, England,
    and,
    a 2" x 8" pneumatic sanding drum and 15 new sleeves,
    and,
    more than 10 pen kits & some blanks,
    I tried a small piece to see if I remembered how,
    Umm, I only paid $75.00 for it, before I even knew it came with all the extra stuff.
    So, How'd I do?
    Aloha, Tony
    Ah,,,to live in Paradise!
    Registered voting member
    30,230
    I'd say you did pretty good there, Tony. Looks like you also turned the requisite bonker. I think you're already slipping into the Abyss.
    If the seller is unable to find the tailstock, you might be able to get one from Penn State Industries. They still sell that lathe. (For $269.95. Yeah, you did alright.) The tailstock may cost about as much as you paid for the lateh, but you'll still be money ahead.
    Honolulu, Hawaii
    1,103
    How'd I do?
    Hi Vaughn,
    I'm happy with it. I saw the PSI sticker (right below the Carba-Tec decal) on it so I figured to check them out for parts if needed. That particular model is not listed on their website, but a newer version is.
    I have one question about the speed controller on this. The motor is 110 volt DC with a potentiometer (sic). It is fairly steady in speed increases as you turn the knob, but sometimes speeds up then levels down a bit. Also, at any particular speed setting the motor will speed up considerably when a load is placed on it, as when you sand the piece turning. Is this a normal charactistic for small variable speed drives? I'm entirely new at these and will be asking questions.
    Thanks for your reply. I was really surprised when the lady I got it from (It was her father's) showed me all the stuff that came with the deal. I would have been content with just the lathe, but those two new chucks, and the sanding drum, well, that was the icing on the cake. I'm going to make something on the lathe and give it to her in appreciation of that good deal. I can even practice on some pens without having to worry about spoiling one or two learning. This is going to be fun, I can see real fast.
    Aloha, Tony
    30,230
    Tony, I have a little Wilton mini-lathe that's similar (but a bit lighter-duty). The speed controller is very similar. (For all I know, they're all coming out of the same factory.) I haven't seen mine speed up when a load is put on it, although sometimes I can hear the motor straining a bit harder. I do see a bit of "settling down" when I change the speeds, but not a considerable amount.
    You might have a bit of dirt and grime inside the potentiometer. One old trick I use on electric guitars with dirty pots is to "exercise" the knob briskly for 30 seconds or so. Just crank it back and forth from one end of its range to the next for a bit. This will often loosen up the gunk and get things working more smoothly.
    Taree Australia
    37
    G'Day Tony
    Boy you did good, that's some haul.
    Cheers
    Bernie
    11,900
    Even without the tailstock, or lathe for that matter, you did alright just on the chucks alone.
    Goodland, Kansas
    4,834
    Ya did good Tony. With all the extra's you probably got at least 3 times what you paid. Like Frank said you got your money's worth just in the chucks. Turning looks good. Keep'em coming.
    Bernie W.
    Honolulu, Hawaii
    1,103
    How'd I do
    Hi all,
    Thanks for the good ratings. I'm just getting into turning and have a lot to re-learn. It's been over 50 years since I was on a wood lathe. (High school)
    I've also got an old Craftsman, all apart, in storage, to be restored someday. I don't have any space for anything bigger than this mini now. I think it's going to work good for me. I like how smooth this lathe runs. Feels well balanced and built pretty well.
    It's a Carba-Tec, model HM-1V. Anyone else have any experience with one? There is a sticker from the original dealer, PSI, and I have checked their website. Like Vaughn said, they still sell one that is just like it, so it can't be all bad. I was thinking of fabricating a tailstock if I can't find one. I'll check with PSI to see what a replacement will set me back. Most of my experience has been in metal work anyway.
    More on this later, as I get time to work with it.
    Aloha, Tony
    15,815
    Hey Tony, welcome to the abyss!!
    Careful with them chucks, they sure look like knuckle busters!!
    You done good, $75.......man, what a deal!!
    Welcome to the Abyss Tony! I'd say you got a good buy.
    One thing you might try is as Vaughn suggested.
    Another suggestion is to turn the lathe on and use the handle of a screwdriver or even a piece of wood and tap near the brush holders on the motor and see if it causes the speeds to change. I've seen dc motors where the brushes get worn and thus too short. They then make a poor/intermittant contact with the armature of the motor. If the speed changes with the tapping I'd remove the brushes and compare their length.
    Even if you have to do some repair I think you got a good buy!
