Results 1 to 5 of 5
Thread: I need a little help
    Apr 2009
    Outside the beltway
    5,250
    If anyone has a Montgomery Ward 2610e or a radial arm saw or one close , I need a picture of the triger wiring. Or for you have anidea of the wiring and can draw it out I would appreciate it.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
    Thomasville, GA
    5,992
    The manual can be found here. Hope this helps.
    Bill Arnold
    Apr 2009
    Outside the beltway
    5,250
    Bill I found that but it doesn't show the wiring or the triger. Thanks
    Thomasville, GA
    5,992
    Page 34 has a diagram showing two red wires from the motor matching up to black and white from the power cord. If you check continuity on the trigger switch, you can determine which terminals close when you press the trigger.
    Bill Arnold
    Apr 2009
    Outside the beltway
    5,250
    Thanks Bill. Once I got back to the shop I was able to pull this up and see it , phone just was not giving me a good reading.
