glenn bradley
- SoCal
All the trim is on and planed down flush with the top.
The recommended angle for the chop is about 2 degrees per the manual. I went a little lees than that and it is still too much. There's no way I could get these jaws to close once the thrust plates were fastened down. This pic is at the maximum pressure that I would ever use. Trying to clamp a test board was a failure ;-(
I backed it off to about 1 degree. I'll re-check after the first BLO treatment sets for awhile.
