Results 1 to 10 of 10
Thread: OT - getting into locked car trunks
    5,268
    My friend has a Chevy Lumina. We have tried to get into her trunk. The key won't turn. Here is where we are at this point:
    She swears it is the right key!
    We've tried WD-40, liquid graphite, and silicone.
    We tried to remove the back seat. There is some sort of cage behind that severely restricting the smallest of us to get in there and unlock it from that angle.
    She is ready to drill it out, but we don't know how to do that.
    We are all poor a church mice, so a locksmith is out of budget.
    The car is a beater, so baling wire to hold it closed later is OK with her.
    It getting close to time to move off campus. She needs her trunk.
    I do have a full selection of drill bits and a cordless driver at hand. How DO you drill out a car lock?
    Suggestions?
    Thanks.
    Steve Clardy Guest
    Been a long time since I've done that one.
    I suggest a heavy screwdriver first. Drive it into the keyslot with a hammer.
    Then get a crescent wrench and put it on the flat part of the screwdriver, close to the end of the screwdriver, then try to turn the lock.
    If that doesn't work then get the drill and bit out.
    Remove the outer chrome ring by prying it off.
    Start with a 1/4 bit, then move up to a 1/2" bit.
    You may have to pick/pry out the pieces.
    Then after the insides are removed, the screwdriver comes back. Theres a slot in the rear of the outer lock cylinder, that you can get the screwdriver in to turn it to open.
    Sarasota FL
    39
    i would use a step bit , pop it right out
    if you have a harbor freight nearby they have them cheap
    http://www.harborfreightusa.com/usa/...layItemList.do
    or a pry bar since you don't care about the car
    looks like the HF links don't work so heres some others for reference
    step bit
    http://www.amazon.com/exec/obidos/se...rocess=default
    pry bar
    http://www.amazon.com/s/ref=nb_ss_hi...0&Go.y=0&Go=Go
    5,533
    another option which might be easier than drilling in, is removing the rear seat upright and releasing it from inside, ymmv.
    -Ned
    Sacramento, CA
    1,367
    Just out of curiosity, have you tried the key used in the ignition? I know older cars had two separate keys, but just thought i'd toss that idea out there
    Also, if the key unlocks the doors, it should unlock the trunk. Take the key that you are told should work in the trunk and try it on the doors - if it doesn't work there, it's likely the wrong key. If it does work there, the trunk's lock is toast and then I'd consider drilling/prying/explosives/etc
    Jason Beam
    Sacramento, CA
    2,784
    If you haven't startee drilling yet, try the key again, only this time bounce up and down on the trunk lid above the lock. This might help if it is just stuck. Worth a try, and it's cheap!! Jim.
    Coolmeadow Setters...
    Exclusively Irish!
    5,533
    Quote Originally Posted by Jason Beam View Post
    -Ned
    Sarasota FL
    39
    you might try posting the question here also
    http://forum.doityourself.com/forumdisplay.php?f=2
    810
    If the vehicle has not had the lock changed then you can take the VIN to your local dealer with proof of ownership and they can usually cut a new key to fit by using the VIN to identify the pattern. I had to have one done for a Monte Carlo that my mother lost the keys for and IIRC it was about $15.
    Charlotte, NC
    1,487
    Are you sure you aren't using a valet key? those will only work on the doors. Is there not a second set of keys? If not take the car to a dealer. They will either be able to get a replacement key from the VIN or may have a means to open the trunk without destroying the lock.
  1. Locked Rabbet Jig
    By Ron Roase in forum Jigs and Fixtures
    Last Post: 01-06-2011, 09:56 PM
  2. Making Trunks
    By Chuck Thoits in forum Flatwork Project Showcase
    Last Post: 05-06-2008, 11:03 AM
