Leo Voisine
- East Freeetown, Massachusetts
Don't use the profile tool path - use the one I circled above. It's not only about the tool - it is the tool path selection.
Look closely at the picture I posted.
When using a "V" bit the bit will fit between the double lines. It will go as deep as it can go until the sides of the angle reach the double lines. See the "V" below. Notice the Green "V" grooving above - as the double lines get wider - the "V" groove cuts deeper.
Using a sharper angle will allow the tool to cut deeper - conversely - a shallower angle will not cut as deep.
In my sketch - I included a couple of closed double vectors. Notice - the ends have a line to close the vectors. If there is a gap, anywhere in the vector, it is considered open.
Just to add a note here - if you make a circle and V-Groove it with this toolpath - you will get a nice eyeball, but be careful how big it is.
