Results 1 to 10 of 10
Thread: first state board test
    Dec 2008
    falcon heights, minnesota
    5,610
    before i closed up for the weekend, i decided to get a test of the state boards done. not that i am inclined to my home state, but i figured it would be a good start. the over all size is 8 x 18 inches. learned a few things on this test run as well. changed the depth of cut from .0313 for the state outline and name to .032. that, and i need to move the holes in about an inch, to get away from the edge, that and i should change the lettering from outline to fill. this one was also a timed run, all in all, just under 22 minutes from start to finish.
    benedictione omnes bene
    www.burroviejowoodworking.com
    4,553
    Thats pretty good time Dan yer catch-n on pretty quick
    A Turn N Time
    Frog Pond Guitars
    Jan 2009
    Carthage,Mo
    887
    You do good work and quick. Looks like you have really found a nitch.
    David
    Dec 2008
    5,610
    funny thing is, is that my niece wants to know how much for the prototype.....
    Thomasville, GA
    6,000
    Good concept, Dan! Those should go over well at your shows.
    Are you doing your boards with Cut2D? Also, what bit or bits do you use for the different parts?
    Bill Arnold
    Dec 2008
    5,610
    thanks bill! yup, done with cut2d. only bits that i used were a 60 degree engraving bit for the lettering and the state outline (at .032" from the surface), and 2 flute end mill for the holes.
    Thomasville, GA
    6,000
    OK. Thanks, Dan.
    Bill Arnold
    Dec 2008
    5,610
    correction, that was a 30 degree v bit that i was using.
    East Freeetown, Massachusetts
    3,022
    Lookin good Dan
    12,264
    Dan this stateboard of yours had me think of those US maps which take all the quarters for the different states. You could setup to do one of those. Even make the states a puzzle piece with a place for its quarter.
    I nearly have a full set still have a few qtrs to go.
  1. chess board for this year's state fair
    Last Post: 07-14-2012, 04:20 PM
  2. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  3. Do you have a state pie?
    By Ron Jones in forum Off Topic Discussion
    Last Post: 11-28-2010, 06:36 AM
  4. Iowa State
    Last Post: 02-16-2010, 06:11 PM
