View Poll Results: Pocket Screw Installation Tool
Voters
27. You may not vote on this poll
  • Drill/Driver, clutched, corded or cordless
    22 81.48%
  • Impact Driver
    4 14.81%
  • Hand tool, manual powered tool of some type
    0 0%
  • Other (teeth, fingers??)
    1 3.70%
Results 1 to 10 of 17
Thread: Pocket Screw Installation Tool Preference?
    I'm curious about what tool(s) y'all use to install pocket screws.
    I got an impact driver last year and just recently had the opportunity to drive a bunch of pocket screws.... I'm not sure I like the impacter for the task... it seems like the flat pocket head kept the screw from over driving, but the impact torque spun the screw and the threads destroyed the hole.
    Thomasville, GA
    5,992
    I use one of my trusty PC 1800D drivers, starting with a light clutch setting. As I start setting the first screw, I increase the clutch until I get a good, tight fit without stripping the wood fibers. Then, keep the clutch setting for the remainder of that segment of the job.
    Bill Arnold
    Depends on the position. Generally a small 12v clutched drill/driver. I also have a Milwaukee Hummingbird and a right angle VS drill. For finer things I drive them by hand.
    Dec 2008
    falcon heights, minnesota
    5,609
    i don't use pocket screws, so i cannot comment.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Nov 2012
    Wapakoneta, OH
    610
    I would expect the impact driver to do just as you described....doesn't sound like a good idea. They go in so easy I've never found a cordless drill to have problems with them.
    13,357
    I generally save the impact driver for driving long screws in construction type projects. Too easy to overdrive and split the wood or strip the hole.
    13,437
    Same here, use a drill and set the clutch, the impact will do as you described.
    Oliver Springs, TN
    1,726
    I use my impact driver, heck I use it for all my driving needs! You just have to have a quick finger!
    12,247
    I use my 12v milwaukee drill and like Bill mentioned set the torque clutch. Tried a driver and had similar experience to you. It did not have a clutch on it so could not control the torque.
    Sep 2007
    Plainwell, Michigan
    4,855
    I have always used my impact driver for years with no issues...........but now the next time I will snap one, better switch to my drill driver before murphy kicks in
  1. Tool for sanding a pocket floor
    Last Post: 02-14-2014, 08:02 PM
  2. Table Saw Blade Preference? - ***UPDATE***
    By Bill Arnold in forum New Tools
    Last Post: 09-18-2013, 10:16 PM
  3. Coarse or fine - pocket hole screw question
    Last Post: 05-28-2009, 03:48 PM
  4. sharpening wheel grit preference
    Last Post: 09-12-2008, 03:26 PM
  5. pocket screw case construction
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 08-26-2008, 02:55 PM
