Results 1 to 10 of 12
Thread: Cottonwood Serving Bowl
    Mar 2015
    Parker County, Texas
    1,508
    I've been doing a fair amount of roughing out bowl to fill the kiln up and this one was through so I finished it up today. It has some of the typical burring in cottonwood but adds to the rustic affect that most of my customers love. The bowl is 12 1/4" in diameter, 5" high, and has a depth of 4". As I always do the wood was sealed with walnut oil and then it received several coats of the walnut oil/shellac mixture while spinning that I use. I kept my usual broad foot on it. Guess there ain't much else to say about it.
    Aug 2008
    Reno, Nv
    3,632
    Cottonwood can be boring...this one is cool grain city!
    4,701
    Quote Originally Posted by Jim Burr View Post
    I'll second that. Dave seems to get more out of cottonwood than I've seen before... I'm thinking there must be a secret trick or something, maybe its the walnut oil..
    Mar 2015
    1,508
    Thanks, guys. There is a secret, sort of. Cottonwood is funny stuff to work with. When you turn it real, real green you tend to take a bath from it from all the water it's holding. After I had this one roughed out, like all of my roughs, I weighed it before it went into the kiln. I weighed 9 lbs. When I took it out after 4 days it weighed about 6. To get the best color from cottonwood is I found is don't rough it out totally green. Let the log age a bit. You lose a little from checking but it usually is worth it. Also, Ryan is right. Part of it is using the walnut oil to seal the wood. It brings out the color more. When I first started turning I used urethane and lacquer for my finishes. After some research I came to know walnut oil and have been using ever since and that's about 7 years. It also allows you to see flaws in the wood that you might not see otherwise and the walnut oil allows you to correct those flaws a lot easier. Then as you know I finish them with a mixture of walnut oil and shellac. In my opinion it's the only way to go. But, as I said it's my opinion.
    May 2009
    Lafayette, Indiana
    2,380
    Dave I agree with the others. The grain in that is really nice. Gives it a very rich look. Nicely done!
    Feb 2012
    2,749
    Very cool! Well done!
    Cheers,
    Roger
    That's a real pretty piece of wood, Dave.
    Tellico Plains, Tennessee
    4,353
    Great looking bowl, I've only had one half a log of cottonwood and got two small bowls from it... I like how it worked and handled... it's a lot like the royal paulownia I have... tendency to tear out, some grain lines and very light weight. Also similar to white cedar.
    Chuck
    Tellico Plains, TN
    S E Washington State
    3,777
    I would have never thought cottonwood could look that nice.
    "We the People ......"
    Quote Originally Posted by Paul Douglass View Post
    Actually, if you get the right piece, cottonwood can be beautiful. My buddy (and occasional FW poster) Curt Fuller has done some amazing pieces out of cottonwood. If you have a Facebook account, this photo should be visible:
    https://www.facebook.com/photo.php?f...type=3&theater
  1. 15" Cottonwood Bowl
    By Dave Hoskins in forum Lathe Project Showcase
    Last Post: 10-11-2015, 11:25 AM
  2. Pecan Serving Bowl
    Last Post: 07-24-2015, 05:46 PM
  3. Cottonwood Serving Bowl
    Last Post: 06-12-2015, 09:20 PM
  4. Cottonwood rimmed bowl
    By Curt Fuller in forum Lathe Project Showcase
    Last Post: 11-21-2008, 05:26 AM
