Results 1 to 5 of 5
Thread: need some refinishing help
    5,176
    Hoping Dave and Jim D. pitch in here.
    The chancel furniture here at church is about 50 years old. The finish, especially on the altar need redone. Looks like some water damage and a delaminating of the finish. Plan is to scrape it all off. Recolor to match communion rail. The baptismal font likewise will need scraping and recoloring. Don't plan to scrape the communion rail. Doesn't need it.
    OK so far.
    I am fairly handy with spaying lacquer though I have never used the water based stuff. Now I am back in California and no NC lacquer allowed.
    Had planned to thoroughly wash and rinse all the surfaces to be sprayed. Want to spray all the surfaces including the communion rail to get the same sheen off of everything.
    Can I spray water based lacquer over any other cured finish? Any particular coloring agent best under water based lacquer? Jim, would you please provide your finishing protocol with water based lacquer, including part numbers and and sources?
    I have a week to get this done, beginning August 3. I do have help with the washing and rinsing and the scraping. And the coloring of the two tops. Spraying, however, is all on me. I have an Apollo HVLP unit with which I am quite familiar and have used to good effect over the years.
    Please help me get ready for this task. Also, I need time to acquire whatever I need beforehand. Thanks.
    5,323
    Carol,
    The waterbornes will adhere to any properly prepped surface. You'll need to scuff the existing finish to provide some tooth, and of course, ensure it's completely free of grease, oil, or other contaminates.
    Since this will be a fairly high wear environment, I'd suggest using Target's EM-8000cv conversion varnish, with the added cross-linker, instead of the EM-6000 lacquer, or the EM-7000 High Build lacquer. The 8000cv will yield a harder, more durable finish overall.
    As for tinting, Transtint dyes work great. You can either use them in the (EM-1000) sanding sealer, or in the finish itself. I'd' likely use the dye in the finish, and build light coats until you achieve the color you want, then put a couple more coats of untinted finish over that.
    5,176
    Thanks, Jim. Where do you purchase the product?
    Not Jim, but I've bought directly from Target Coatings in the past. Here's the EM-8000CV:
    http://targetcoatings.com/products/i...em8000-series/
    And the EM-1000:
    http://targetcoatings.com/products/s...anding-sealer/
    Looks like the Dealer List doesn't include anyone in your area, Carol...
    http://targetcoatings.com/find-a-dealer/
    5,323
    I buy mine direct from Target. They ship promptly, and I usually get delivery within two or three days.
  1. Refinishing old oak?
    Last Post: 04-12-2013, 08:34 AM
  2. Rut Row - floor refinishing
    By Leo Voisine in forum Carpentry and Construction
    Last Post: 12-22-2011, 04:42 PM
  3. Refinishing Question
    By Jeb Taylor in forum Finishing School
    Last Post: 05-31-2011, 01:05 PM
  4. My first refinishing job, complete!
    By allen levine in forum Finishing School
    Last Post: 07-23-2010, 09:11 PM
  5. Help with refinishing..
    By Greg Cook in forum Finishing School
    Last Post: 11-21-2006, 02:08 PM
