Results 1 to 10 of 11
Thread: deer grunt
    Oliver Springs, TN
    1,726
    deer grunt
    First one of these I've made. With deer season just around the corner, I'm going to try and sale a few. This one is maple with a little curl showing.
    3,132
    John nice looking call. I personally don't care for the plastic tube that comes with the kits, so i don't use them on mine. Like the all wood calls better.
    Oliver Springs, TN
    1,726
    I agree Stephen. I ordered a couple of the kits with the tubes so I will have them around. The next ones I plan on making all wood. A question for you. Do you turn yours on a mandrel? How do you drill out the tube? I guess that's a couple of questions.
    3,132
    Quote Originally Posted by John Daugherty View Post
    John i drill mine on the lathe. Just put the blank in a chuck and drill all the way through. Then i'll put it on the mandrel. Usually i'll drill out a number of blanks at the same time. I know a lot of folks drill on a drill press, but mine is just a little bench top, and to me it's tons easier just to do every thing on the lathe. Seeing your, makes me want to go make some more as i still have a number of kits.
    Yorktown, Virginia
    5,014
    Great looking call. I'm looking forward to seeing what you come up with in an all wood call.
    Mar 2015
    Parker County, Texas
    1,497
    Looks good to me. Like the rest, I'd like to see it all wood. Can't wait to see that! Great work!
    Oliver Springs, TN
    1,726
    Thanks Stephen, I think I'll start drilling them on the lathe. Both times I've used the DP I've gotten some run out. I checked to see is the bit was perpendicular to the table and it is. It's probably something I'm doing. On the two I've posted I drilled about half way on the lathe reversed the blank and drilled the other way and they've met both times. I don't have enough travel on my tail stock to drill all the way in one pass.
    Here's number two. This one is spalted maple and it's 6 inches long.
    Thanks to you too Ted.
Name:	spalted maple.jpg
    Aug 2008
    Reno, Nv
    3,632
    Great addition to your strikers John! How do they work?
    May 2009
    Lafayette, Indiana
    2,380
    John, both of those look great. Those should come in handy.
    11,831
    I've made several of those. Like others I don't use the plastic tube. I have drilled on lathe and dp. BTW, the grunt works. I once killed a buck that walked up within 15 feet of me while I was using the call.
  1. grunt calls
    By John Daugherty in forum Lathe Project Showcase
    Last Post: 11-14-2015, 05:03 PM
  2. Another grunt
    Last Post: 07-31-2015, 02:15 AM
  3. Yes Deer
    By Ken Cook in forum Flatwork Project Showcase
    Last Post: 11-26-2014, 11:25 PM
  4. More Elk and Deer
    Last Post: 05-18-2009, 10:31 PM
