Results 1 to 10 of 25
Thread: squaring a large timber ?
    Oliver Springs, TN
    1,726
    How would you square (crosscut) a large timber say a 6x6, or 8x8?
    4,699
    You mean your Radial Arm Saw is to small for this one?
    Clamped guide with a skill saw, kerf all 4 sides as deep as it'll go (possibly in multiple passes/side if need be to make it a non-scary cut). Finish the cut just shy of the "good side" of the kerf with a hand saw, clean up the handsaw cut with a block plane or large chisel taking light paring cuts.
    Austin, Texas
    1,448
    If you have a big (heavy duty) bandsaw, I would flatten one side on the jointer, cut a side square to it on the bandsaw (then joint the square size if your saw isn't perfect), then use the planer for the other two sides.
    Charlie Plesums, Austin Texas
    4,699
    On of us is missing what you meant when you said "square (crosscut)" - I thought you meant how to crosscut it perfectly square?
    Oliver Springs, TN
    1,726
    What you said Ryan. I've got a few timbers that I'm going to be cutting soon and I need the ends square. I was going to use your method, but was just wanting to see if anyone had a different way.
    A really good sharp handsaw, how do you think our grandfathers did it?
    4,699
    I'm with you in spirit but sometimes my saw is apt to wander so if it's really critical I'll take a little help from my friends.
    Feb 2012
    2,749
    I would just give up, and use something else.
    Cheers,
    Roger
    I see these used over here all the time for about $10, no kidding....
    382mm blade (15"), cut depth of 143mm that is 5-5/8" in one pass.
    Too bad they don't sell them in the US.
    Jul 2007
    DSM, IA
    5,719
    They sell those over here Stu...or they used to anyway. I cut over 100 6x6 posts for around 25 decks on a summer framing job back when I was young. Heavy and scary is all I remember.
    My Website
  1. Some Timber Framing
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 01-07-2015, 03:16 AM
  2. Squaring edge of toothing plane blade
    By Jim Moore in forum Neander Woodworking Q&A
    Last Post: 05-15-2014, 02:18 PM
  3. Squaring lumber
    Last Post: 12-13-2007, 01:54 AM
  4. TIMBER!!!
    Last Post: 10-23-2007, 06:24 PM
  5. Squaring boxes/drawers/etc.
    By Marty Walsh in forum Jigs and Fixtures
    Last Post: 10-01-2007, 11:30 AM
