Chris Mire
- Southern Louisiana
awhile back i was asking questions in the finishing forum about safe finishes for a crib i was making for my lil man who is on the way. well after some thought and research i decided to just stick with a finish i know, minwax satin poly, their website claims all their finished are non toxic, and mommy promised to whip some tush if he tried to take a taste of the bed anyway.
so after 2 coats of an olympic oil based stain "mocha brown" we had the coverage we wanted, really dark and i preceded to apply 3 coats of the satin rubbing with 0000 steel wool between coats. it came out pretty good, mommy is very happy and that is the most important thing.
it's a little different than most cribs, it has a modern feel which we like and it has an integrated bookcase on one side.
I used alder and 3/4 alder ply. the rails are mortise and tenons done with the delta mortising attachment for my drill press. which was interesting because I had to move the table of the bench top drill press out of the way to be able to get the rails under the bit. took a little figuring and thankfully only a one time setup.
everything else was put together with biscuits and lots of glue. the side opposite of the bookcase is actually two panels of 13/16" alder rails and stiles with a 3/4" ply panel, tongue and groove construction. i wanted it to look thick but not have the weight of solid wood that size.
anyway, enough babbling, here it is.
i am now working on an armoire and changing table with hutch to go with them. hoping to be in the finishing stage this weekend. fingers crossed.
thanks for looking
chris
thanks for looking
chris
