Results 1 to 10 of 11
Thread: Delta Band saw motor
    Tellico Plains, Tennessee
    4,351
    Hey all, I've come to the collective to see what info I can glean from all you smart folks...
    I have a Delta 28-276 14" bandsaw, MOTOR-3/4HP-1PH-115V according to the manual... with a grizzly riser installed..
    I've watched all the videos and read as much as I could find about tuning the saw and pretty sure it was tuned up okay... but here lately when I run the saw, i get a clatter sound in the motor area... I took the blade off this afternoon and ran just the motor and there was the clatter... thinking I have something loose in the motor housing or a bearing has gone bad....
    I was pretty sure I had a motor problem and started looking at parts... Delta parts as well as eReplacement... according to both, this motor is obsolete, discontinued and they don't offer a replacement... I've emailed eReplacement and asked if they had a cross reference, and according to their customer service, none .... also emailed Delta, but no response as yet...
    Already thinking may have to bite the bullet and buy another motor... or may be able to take it locally to a shop that can rebuild this one.. any other suggestions from the collective??
    Chuck
    Tellico Plains, TN
    Nov 2012
    Wapakoneta, OH
    611
    My Delta planer motor does that, and it turned out the fan came loose from the shaft. The fan I have is plastic, and the held to the shaft in a rinky dink fashion, just kind of clamped...no key or anything. Anyway, I put in a bushing to make it fit a little tighter and the noise went away. If the motor you have is TEFC, the fan is easily accessible by removing the rear most cover. Of course, that's only one of 3 dozen things it could be.
    11,832
    Check what Fred said. Then if problem exists and you do have a local rebuilder, I would take there. If you need a new motor, there are many options. Flea markets are loaded with them. Harbor Freight has great prices.
    5,321
    I replaced mine with a NEMA 56 framed 1 hp. motor a few years back. A straight-forward, simple bolt-up.
    4,351
    Finally heard from Delta... they don't have a cross reference on the motor... suggested I go to local machine shop/electrical repair and gave me the specs to look for... so tomorrow I'll see if I can open the motor housing and see if hopefully, it's a simple problem I can fix... otherwise we have a nice electric motor repair place in Athens, about 40 miles from the house.
    Chuck
    Tellico Plains, TN
    Independence, Kentucky
    1,355
    Chuck, be sure to mark the end bells before taking them off so they can be put back in the proper orientation.This is an important step.
    Just in case you didn't already know.
    4,351
    Quote Originally Posted by fred hargis View Post
    I got the motor off the saw yesterday... then discovered I don't have the tools to pull the motor apart, so running it over to an electric motor repair shop later this morning... after I got it on the work bench, I could see the fan was definitely loose. After talking to the repair shop, it will be cheaper (always a good word in my vocabulary) to let them fix it than to go buy the tools to do it myself.
    Chuck
    Tellico Plains, TN
    Feb 2012
    2,749
    That's wise. I find that when I take things apart, they very seldom get back together. Leave it to the professionals.
    Cheers,
    Roger
    Jun 2012
    Laurinburg NC
    316
    Wow Im glad Im not the only one that has that problem..As I have gotten older I have become very selective on the projects I jump
    off onto.....saving me some money and time for things I like to do!
    30,017
    Out of curiosity, what was the tool you were needing to open up the motor?
  1. Delta 10" midi lathe motor
    By Billy Burt in forum Turning Tool Questions and Show & Tell
    Last Post: 10-23-2012, 03:24 AM
  2. Delta band saw
    By ken werner in forum Classified Ads
    Last Post: 10-19-2012, 01:51 AM
  3. Delta 14" band saw Indy area
    By Ron Jones in forum Classified Ads
    Last Post: 04-13-2012, 03:05 AM
  4. Delta 14" Band Saw
    By Gayl Beals in forum General Woodworking Q&A
    Last Post: 12-21-2010, 01:33 AM
  5. 14" Delta Band Saw @ Lowe's for $250 (YMMV)
    By Jeff Bergman in forum Hot Deals
    Last Post: 01-28-2010, 05:24 PM
