Results 1 to 8 of 8
Thread: Help---Part Needed
    Feb 2015
    Norborne MO
    3
    Help---Part Needed
    I have a Rockwell 9" table saw, the blade height adjustment gear which was plastic broke. It is half moon shape with teeth along the bottom. It is an old saw but its a power house. The part is not made anymore (of course) .
    Catolog #34-625
    Serial #DP5739
    ANY HELP IS GREATLY APPRECIATED ...
    Thanks Ben
    5,172
    Did you try erelacementparts.com? and the old machinery site? Do you have the pieces? Find a Makerspace nearby abd see if you can get someone to 3d print one for you out of plastic. Google Makerspace. Hope that gets you started.
    Feb 2015
    Norborne MO
    3
    Yes I tried them, I have the diagram from Rockwell. Took it to a machine shop his estimate was $300.00 to cut a new one. Old one shattered in to pieces.
    Ben
    Dec 2008
    falcon heights, minnesota
    5,610
    Can you send me the diagram? I'm going to check with someone I know that has a 3d printer.
    benedictione omnes bene
    www.burroviejowoodworking.com
    Do 3D printers print with plastics that will take that kind of pressure/torque? That's cool!
    East Freeetown, Massachusetts
    3,022
    Send me the diagram. Possibly I can make it for you maybe save you some money.
    voisil@comcast.net
    Apr 2008
    Independence MO
    561
    Are you a member of the Vintage machines forums? (used to be the Old Woodworking Machines name)
    They also might be a good source. (Carol mentioned it, but if you didn't know the name that is helpful to find it)
    Really, folks? This is the Internet.
    Here are the links:
    http://vintagemachinery.org/home.aspx
    http://www.owwm.org/
  1. Replies: 17
    Last Post: 02-26-2014, 06:09 PM
  2. Part needed
    By larry merlau in forum Neander Tool Questions and Show & Tell
    Last Post: 03-10-2009, 01:50 PM
  3. need a new part
    By larry merlau in forum Old Iron
    Last Post: 01-20-2008, 01:03 PM
