Results 1 to 9 of 9
Thread: Is it toast?
    Constantine, MI
    7,888
    Is it toast?
    I was very happy when a friend dropped this off for me. He had been helping clean out a friends garage and spoke up when these were to be given away. The two #4's are in ok shape, as is the block plane. All the other stuff is just useful. However, I was really pleased to the the Bailey #6. Been wanting to get my hands on one for a while.
    However, my smile dimmed a bit when I took a closer look. I'm not really a plane aficionado, so give me some guidance, please. Is this plane beyond saving? Is it toast?
    www.wrworkshop.com
    4,698
    The chip in the mouth is behind the blade so it shouldn't really cause can problems. Make sure its not spalled out but otherwise don't worry about it imho.
    The other divot shouldn't be a problem either unless it raised and if so just sand it out enough so it doesn't mark your work.
    Make sure the blade is sharp and the cip breaker is seated well on the blade and set less than 1/16" (or closer) to the edge wax the sole and rock and roll. Looks like a perfectly good user to me.
    5,317
    Pretty much what Ryan said.
    The hole in the sole looks like it might be just under one of the tote's bolts, so it might break out later - or maybe it'll last forever. Who knows?
    In the meantime, it's a very usable plane.
    Apr 2013
    Nashua Iowa
    130
    The handyman isn't worth bothering with, it is rough cast iron on cast iron. The chip out in the six won't hurt a thing. With the patient dates it looks like it should have a full machined face on the frog which is quite desirable. The block is very usable, clean them use and use them.
    Tom
    5,317
    Disagree regarding the Handyman. With some fettling, it can be quite useful. Granted, it'll never be the equal of a Bedrock, but it can be a good 'user.'
    Feb 2012
    2,746
    That Handyman is probably better than a lot of Stanley knock-offs.
    Cheers,
    Roger
    5,317
    Better than the "new" Stanleys that are being marketed now, too.
    Constantine, MI
    7,888
    Thanks guys, I knew I would get good info from you! I'll set these aside for now, but I think they will make great winter projects.
    www.wrworkshop.com
    Just spend some time lapping the bottom of that plane, I would worry it could need it, as this plane may have been abused.
    Lapping it should not be hard, you will figure out quickly if it is warped or not.
  1. I think it's toast....
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 11-14-2012, 04:10 AM
  2. Holy moly....the euro is TOAST!
    By Joseph Shaul in forum Off Topic Discussion
    Last Post: 06-06-2010, 07:38 PM
  3. Nikon Toast - Ressurected!
    By Rennie Heuer in forum Off Topic Discussion
    Last Post: 01-20-2009, 11:52 PM
