Results 1 to 7 of 7
Thread: The Next Hollow Form!!
    15,585
    Yep, started another one!
    These things are like potato chips, can't just have one!!
    Attachment 8155 Attachment 8156
    These two pics are the HF on the lathe, with the outside done, no hollowing.
    Attachment 8157 Attachment 8158
    This wood has some nice grain in it, but is is was much easier to hollow out than that last one.
    Attachment 8159 Attachment 8160
    Should make a nice simple HF, good practice. It is hollowed to about 3/16", or less. Into the DNA tub it went!
    Attachment 8161
    While I was doing this one, I was having a bit of a problem with the D-handle hitting the wall, so I moved the headstock out a bit, and adjusted the captive part, and BOY this worked better!
    11,697
    Should be nice when done. I see yours swivels.
    Wats that crane-like thing on top?
    15,585
    That is my laser rig, makes hollowing way too much fun
    29,086
    Although I typically don't rotate my headstock, I may have to try that trick with mine. (The outboard tool rest on mine is junk, so it's worse than useless...it's dangerous. But in this application, since the outboard toolrest is not involved, a slight rotation should be fine.)
    11,697
    Saw it on your other thread. Neat.
    11,697
    We have kidded a lot about this. But, fact is, I rotate mine out some because it removes the necessity of having to reach and lean when hollowing. Maybe younger, taller guys don't have a problem with that but for some of us it is far less tiring and makes the job more enjoyable. And, Vaughn, I suggest you look for a local welding shop to make you any kind of rest or extension you want. I get mine made for $10.00 each, their shop minimum.
    Goodland, Kansas
    4,834
    I never thought of rotating the headstock either. Great idea.
    Bernie W.
  1. first hollow form
    By Clark O'Neill in forum Lathe Project Showcase
    Last Post: 04-14-2008, 02:08 AM
  2. Hollow Form........ WIP
    Last Post: 04-08-2008, 05:50 PM
  3. How long does it take to hollow out a small hollow form?
    By Mike Hirsch in forum Turning Tool Questions and Show & Tell
    Last Post: 04-04-2008, 07:47 PM
  4. Box? Not exactly. Hollow Form? Well, no....
    By Kerry Burton in forum Lathe Project Showcase
    Last Post: 05-12-2007, 10:28 AM
  5. Hollow Form
    By Bernie Weishapl in forum Turning Tool Questions and Show & Tell
    Last Post: 04-30-2007, 10:34 PM
