Results 1 to 10 of 11
Thread: Replacement variable speed belt for Craftsman wood lathe 351.217150.
    I found that Gates has a belt that works just great # 1632v210. To replace the belt just loosen set screw on the spindle and then remove the plate on the drive shaft and pull the upper pulley off the spindle. You can now remove belt. You now need someone with strong fingers to compress the spring so you can insert a small 5/8 x 5/8 block of wood between the sides of the movable spindle pulley. Place belt over both pulleys and slide the spindle pulley on then and remove the block of wood. This might take 10 minutes to complete. Good luck.
    11,825
    Or consider a link belt. Run very smooth and do not require any disassembly. Harbor Frieght seems to have the best prices.
    15,806
    I think this is a reeves drive lathe Frank, so the linked belt won't work
    30,002
    Stu is right...a link belt will not work on this lathe for either of the belts it uses.
    Thanks for the tip, Wesley. I used to have that model of lathe, and changing the belt was a chore.
    And welcome to the forum.
    11,825
    I thunk that thought about it maybe being a Reeves drive. But his description of changing is, to me, odd. Just open the variable pulley and slip new belt on. No spring compression or broken thumbs required.
    BTW, why won't a link belt work? Just asking......
    30,002
    The mechanism in the Sears lathe is different from other Reeves drives I've seen. It's not as straightforward as others to replace the belt on. The Reeves drive belt is also about twice as wide (if not more) that a link belt. There's another drive belt on that lathe that's also an oddball. It's only about three inches in diameter and it's much wider than a link belt, too. It's also got teeth on the inside of the belt that mesh with a cog-like wheel on the motor.
    11,825
    Hokay.
    North West Indiana
    6,097
    Frank, since you have never had the opportunity to "experience" one of these uhum, fabulous cough cough machines, I in fact have one and won't sell it to anyone to inflict more pain. You or any family member that wants it can have it for free. Pick up at my home or pay the shipping. Seriously this is an offer!
    Jon
    11,825
    Quote Originally Posted by Jonathan Shively View Post
    I can hardly refuse your offer. Oh, well. I had a Grizzly with Reeves drive. Really a good lathe, especially for the price. Belt was easy to change.
    30,002
    Despite all the maintenance and repair grief my Craftsman lathe gave me, it did help me make some of my favorite pieces, and it fed my desire to turn bigger and better, which motivated me to buy my Powermatic.
  1. drive belt shot on my craftsman 351.217150
    By hu lowery in forum Turning Tool Questions and Show & Tell
    Last Post: 08-05-2013, 10:56 PM
  2. Craftsman Verriable Speed Model 351.217150
    By John Ledrich in forum General Woodturning Q&A
    Last Post: 05-29-2013, 12:00 AM
  3. Craftsman Model 351.217150 Lathe's Variable speed control broke
    By Dimitri Schreiber in forum New Tools
    Last Post: 08-13-2010, 09:42 PM
  4. Variable Speed on Lathe
    By Rich Aldrich in forum Turning Tool Questions and Show & Tell
    Last Post: 09-25-2009, 10:55 PM
  5. 1HP variable speed lathe for less than $400??
    By Jeff Bower in forum General Woodturning Q&A
    Last Post: 05-21-2009, 08:58 PM
