Results 1 to 7 of 7
Thread: Catch as catch can...
    Feb 2012
    2,746
    I got back on the lathe for a short time this afternoon. I am holowing out the inside of an 8" x 5" bowl. I have been doing this wrongly, but with a method that works, in effect using my bowl gouge like a scraper, and doing pull cuts from the centre hole to the rim. Now I am trying to do it by a more orthodox method, following videos by Brendan Stemp and Robbie the Woodturner. Their advice seems to be the same as some others that have been suggested to me, but their illustration is much clearer.
    I am getting catches when I make the transition from the sides to the bottom. I am trying to do it the same way these two nice gentlemen work, but I am missing something. However, my gouge is tilted 45º to the direction I am going, and I can't see where I am going wrong.
    Later in the week I may be able to talk LOML into taking a video of my technique, but until then, can anyone suggest what I may be doing worng?
    Cheers,
    Roger
    Jul 2007
    DSM, IA
    5,719
    Roger, I use the pull from the middle cut all the time to remove lots of wood fast. Nothing wrong with that in my opinion. Tough to get a clean cut with it, but it works well to remove wood fast. As far as the catches, the first thing that comes to mind is your tool rest height. Is it above center? If so drop it a bit below and try again. Second, how far away from the wood is the tool rest? The closer the tool rest the better.
    My Website
    Yorktown, Virginia
    5,009
    I think you might be losing bevel contact when you turn the corner. I keep a bowl gouge with a more traditional grind, maybe even a bit steeper than traditional to work the transition and the bowl bottom. If you look for 'bottom feeder' bowl gouge grind you will see essentially square tips beveled to 75 degrees with a slight sweep back on the corners to avoid catches. I learned of this grind from a class with Trent Bosch years ago and have been using it with good success.
    Feb 2012
    2,746
    JThanks! Later today I tried a gouge with a more traditional grind than the swept back grind I was using, and had more success with it. Still not perfect, but only God is perfect, so what do I expect?
    Cheers,
    Roger
    Aug 2008
    Reno, Nv
    3,632
    With few exceptions, catches are a flaw in technique. Roll the hand holding the handle of the tool clockwise as you reach the center of the bowl.
    Oct 2009
    Harrisburg, NC
    140
    In addition to what others said you may stay with your standard grind but add a second bevel as shown. So, it may be ground at 55* and then at 40* to grind off more of the bevel allowing you to scoot around corners easier because the bevel is much shorter.
    Here is a Glen Lucas double bevel shown at CraftSupply. I tried the bottom feeder or traditional but my hands are not steady enough to keep the corner out of the wood. With the double bevel the wings are still swept back. The more upright wings do provide a steeper angle of cut but for me it is a trade off of slicing action vs control.
Name:	Lucas CraftSupple Double Bevel.jpg
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    Feb 2012
    2,746
    Jim, it's the flaw that I'm looking for! I will try that, thanks.
    Mike, thanks for reminding me. I had thought about putting a secondary bevel on the tool, but actually forgot to.
    Cheers,
    Roger
  1. Catch up on the projects
    By Drew Watson in forum Lathe Project Showcase
    Last Post: 05-14-2010, 10:36 PM
  2. ..did anyone catch this ?.......
    By James Edwards in forum Off Topic Discussion
    Last Post: 01-27-2010, 12:10 AM
  3. Warning – Just had a Catch!
    By Steve Schlumpf in forum Turning Tool Questions and Show & Tell
    Last Post: 05-31-2009, 11:31 AM
  4. I'm going to catch grief for this....but .....
    By Ken Fitzgerald in forum New Tools
    Last Post: 12-15-2007, 12:38 AM
  5. A few projects to catch up on................#3 and another kitchen
    By Mark Rios in forum Carpentry and Construction
    Last Post: 06-06-2007, 01:02 AM
Tags for this Thread
