Results 1 to 10 of 11
Thread: 1964 Powermatic Jointer with rust on feed tables
    I'm restoring this old jointer that's got rust on the feed tables. I've tried WD40 and a scotchbrite pad as well as 0000 steel wool. This rust is deeper than this approach will address. I'm wondering what the next step should be?
    Not suggesting either of these is the next step, however I to have access to a blasting cabinet as well as a mill.
    Thanks!
    Yorktown, Virginia
    5,022
    Hi Bob. Welcome aboard. I can't help beyond what you have already tried, but I bet there are a few people here with derusting expertise that will chime in. Glad you found us.
    9,077
    Deep stains are a badge of honor . . . just kidding. I thought I would make you feel better. I have lifted some severe shadows out of cast iron with Rust Free. These were "spot" fixes and not entire surfaces. It is caustic and can do more harm than good if you don't follow directions. On the other hand it has removed things I thought would never come out.
    North West Indiana
    6,099
    If you haven't tried it, many times I have cleaned badly rusted items with liquid drain cleaner. Just go to your local dollar type store and get any type, The Works, works for me.
    Jon
    5,323
    Are the tables smooth after the WD40 treatment, just stained discolored? Or are they pitted, with deep craters and a rough surface?
    If they're smooth, I'd just leave them alone, and live with the staining. It won't affect operation.
    If they're heavily pitted, then refinishing - preferably by Blanchard grinding - is in order.
    Thanks for the ideas! Here's what I've done so far on the none machined side of the fence.
    Oct 2011
    Cleveland, OH
    8
    Single edge razor blade as a scraper. takes all the layers of rust of down to clean metal. Then use the scotchbrite and steel wool methods. I use one of those retractable blade holders for the razor. I cleaned a Delta 6" long bed tables in about 30 minutes with one or two blades.
    Sep 2007
    St. Louis, MO
    583
    A lot of folks swear by "Evaporust". I've always had good luck using electrolysis. For a jointer, even if it's pitted in areas, as long as it registers flat along the length of the tables, the rust won't effect the machine's accuracy or useability. Before I got set up for electrolysis, I used Boeshield "Rust Free" with great results. Some people use lemon juice (citric acid will eat the rust).
    Good luck with it.
    paulh
    Dec 2013
    So Cal
    2
    Electrolysis, my machines sat for 20 plus years uncovered In a metal building, take everything part (real pain) and cook it for about 24 hours. Gets down deep. Google it.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    11,833
    My thought zactly. No gold stars for pretty.
  1. Eric Clapton's 1964 ES-335 Tribute Guitar - Final Soundcheck
    By Jason Beam in forum Flatwork Project Showcase
    Last Post: 09-27-2015, 01:20 AM
  2. Looking at powermatic model 60 jointer
    By Dave Black in forum Old Iron
    Last Post: 09-21-2013, 11:07 PM
  3. Powermatic Model 50 Jointer
    By Matt Meiser in forum Old Iron
    Last Post: 07-16-2008, 05:31 PM
  4. Powermatic 8 inch jointer. Seattle CL, 200 bucks !
    By Scott Donley in forum Hot Deals
    Last Post: 02-20-2008, 01:19 AM
  5. Powermatic 54a 6" jointer for sale
    By Gary Herrmann in forum Old Ads
    Last Post: 07-21-2007, 01:34 AM
