Fair entries
Jim DeLaney
Austintown, Ohio
Just three items this year.
Intarsia chickadee plaque - maple round, with cherry, walnut, maple (dyed) poplar and ebony bird.
Angular jewelry box in cherry. Front and sides all taper at 15°. Drawers ride on center rails to keep them aligned.
Nice work Jim,
That jewelry box is a looker!
I like the end grain chickadee - if you don't mind I have a couple of practical Q's on that:
  • with the background being end grain did you do anything to deal with wood movement in the inlaid pieces? It seems like it should be fine on a smaller piece like this but I've been eyeballing a much larger piece for a while and that's been one of my fears/hangups so figured I'd ask in the general sense :D
  • How did you glue it with all of the end<->side grain contact? Just a seal coat and then glue seems sufficient but thought I'd ask if you have any tricks while we're here.
Thanks!
...I like the end grain chickadee - if you don't mind I have a couple of practical Q's on that:
Thanks!
The pieces aren't inlaid. They're surface mounted using white glue. The log slice was/is quite dry, having been in my barn for several years, and it's small enough, and the chickadee parts are also small enough that I hope/don't think movement is going to be a problem. Time will tell...
Thanks Jim. For small pieces I think it's likely OK, but will certainly be interested to hear of there are any issues or not.
Nothing to add to what has been said Jim, I love the box and I can see the merit of the intarsia work. Please dont get me wrong, it is only that I'm not a fan of intarsia although I can tell the good from bad apart, and that is GOOD!
Nice job on all of the pieces, Jim. I especially like the rounded front of the jewelry box. :clap:
Thanks Vaughn! The rounded front was an 'interesting' project in itself. With the radius, coupled with the 15° tilt, it got a bit challenging. Note the grain match - that's because the whole front started as a single 10" wide piece, rough shaped with planes and spokeshaves, then sanded to finish, using a template to keep the radius constant. Took a while, as did making the drawer sides/bottoms with the 15° tapers. The drawers ride on a center 'rail guide' to keep them aligned.
Update:
The jewelry box took a second place in its class.
The walking stick and the chickadee plaque each took first place in their respective classes.
I'm pretty happy with the results.
Congrats Jim. I was thinking of your work today. Thought i had made a post on this thread now i see i did not. (my bad). Anyhow nice projects man and paid off.
