Results 1 to 10 of 14
Thread: Laser with vCarve Desktop and Mach3
    13,462
    I was finally able to get a good configuration and output from vCarve Desktop that works with Mach3
    I still have some tweaks to do to the Postscript processor, but here was the test run. Was running at about 150 ipm, which is a bit fast, need to slow down to about 80 - 100 to crisp up the lines some, there are some delays I need to work out with the M03 and M05 commands, seems like it's pausing a lot between them.
    The final output.
Name:	2015-08-29 21.24.20.jpg
    Also did one that was just an outline, each are about 4" x 4". This one was ran about 60 ipm, so see the start/stop points burned a little more.
Name:	2015-08-29 21.25.04.jpg
    Looks like you're cookin'.
    4,701
    Those actually look pretty darn good from here! Certainly a nice little addition to your existing setup.
    13,363
    Fun stuff!
    Sacramento, CA
    1,367
    Nice Darren! Great work, man!
    I keep wanting a laser head for mine ... one of these days
    Jason Beam
    Sacramento, CA
    13,462
    Quote Originally Posted by Jason Beam View Post
    I'm happy with this one, but I'd probably go with the 2.8w if I was to do it again rather than the 2w. However, the driver I got is the same as the one used on the 2.8w, so will just be a mater of updating the laser itself. I'm thinking about rebuilding the mount for my router and making it where the laser can ride along (detachable), so I can do cutting and engraving operations without having to remove the router each time. Probably would take the laser off during the cutting operations though.
    Thomasville, GA
    6,000
    You sure are making it difficult for me, Darren! I know I'll have to add a laser to my SO2 before long!!!
    Looks like you've got a good start with your system. Looks pretty good from here!!!
    Bill Arnold
    East Freeetown, Massachusetts
    3,022
    I sure am jealous about the Laser.
    Maybe after I get past my new CNC Router I can look into Laser - that is several years away
    13,462
    I might have found a solution using a DAC (digital analog converter) that uses the z axis steps to control the laser's intensity to allow mach3 to do gray scale image engraving.
    Sent from my SPH-L720 using Tapatalk
    12,264
    Now you cooking with gas
    Oh before i am misunderstood i dont mean gasoline. lol where i came from most cooking is done with electric stove and we always regarded gas as a faster hotter alternative.
  1. Mach3 Pendant
    By Darren Wright in forum New Systems and Builds
    Last Post: 01-19-2016, 03:01 PM
  2. V-Inlays in VCarve
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 10-29-2015, 04:58 AM
  3. Google Chrome Remote Desktop
    Last Post: 01-15-2013, 01:25 AM
  4. Good Quality Wood For Desktop
    By Kris Petrosky in forum General Woodworking Q&A
    Last Post: 11-18-2011, 07:12 PM
  5. View on desktop
    By Bart Leetch in forum Off Topic Discussion
    Last Post: 08-26-2010, 09:09 PM
