- falcon heights, minnesota
allen, as to your finishing, what grit is your final when sanding? i usually start with 100, then work up to 2000, then on to the micromesh, from 2400 through 12000. once you get past the 2000 grit (600-2000 grit available at your better car parts stores), it is just 2 or 3 light passes with the micromesh, as this will be polishing steps. hope this helps.
