Results 1 to 10 of 22
Thread: How to best attach a top to a table base
    13,360
    I'm hoping I can get a reply to this question without a whole lot of smart aleck comments.
    If you had a table top and a base that met like this, how would you attach the two?
    My thought is to put a threaded insert into the table top, and a recessed slot on the support with a bolt and washer going through the support to allow for side to side wood movement.
    Thanks in advance for your serious replies and help.
    Thomasville, GA
    5,992
    I'd go with figure 8 connectors on the inside of the cross members.
    Bill Arnold
    13,360
    Would those be strong enough to lift the table? The legs and the top are going to be pretty darn beefy, i.e. weigh a lot.
    Thomasville, GA
    5,992
    Your original thought is probably best in that case.
    Bill Arnold
    Yorktown, Virginia
    5,011
    I like your idea, Brent. Another thought would be to attach a piece of metal angle to the inside of the cross piece and lag bolt through it into the top using elongated holes in the metal to accommodate movement.
    13,360
    It seems the big thing is to allow for lateral movement. I like the idea of a threaded insert over a lag bolt, but I think I might use some removable thread locker on the bolt to prevent it from backing out over time.
    The cross piece is pretty beefy, so should be able to cut the slot and recess with a router easy enough.
    13,439
    I think the threaded insert idea should work, perhaps do a stationary hole in the middle of the support on each end, then oblong bolt slots on the outer ones.
    13,360
    Really like the idea of 3 on a side. That should work.
    May 2011
    Cape Cod, Ma.
    1,553
    Brent I used to have a maple butcher block top with a similar base. The way the manufacturer had set it up was to have 2 holes at each end that were wider than the bold. They used standard woodthread lags and washers.
    If memory serves it was a 3/8 lag and washer. The hole was about 9/16 plus the appropriate countersink to hide the bolt head. This allowed the top to move and not split.
    12,251
    I would like to ask/suggest (dunno) that surely this attachment could be achieved by a large sliding dovetail. Given thickness of the top could this not be done ?
    I dont know just trying to think of a different way of attaching.
    Would add a nice feature to the piece.
    http://www.google.ca/search?q=tablet...7xCQy8AIKRM%3A
  1. I found space on my table saw's mobile base to store several systainers
    By Frank Pellow in forum General Woodworking Q&A
    Last Post: 03-29-2012, 07:13 AM
  2. LV router base plate for table
    By Cynthia White in forum Classified Ads
    Last Post: 11-03-2011, 12:07 PM
  3. Trestle Table Base
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 08-28-2010, 09:36 PM
  4. trestle table base idea
    By Chris Mire in forum General Woodworking Q&A
    Last Post: 10-29-2008, 01:24 AM
  5. Mobile base for table saw
    By Dennis Thompson in forum General Woodworking Q&A
    Last Post: 06-13-2007, 01:06 AM
