Results 1 to 3 of 3
Thread: LED Lit Beer Tap Handle
    13,462
    I've been throwing around the idea of making some beer tap handles on the cnc. I'd like to make them where I can update the labels easily, so decided to go with a little frame in the handle to hold the label. Well got to thinking it would be nice if they could be lit up as well.
    I ordered 10 of these waterproof RGB LED lights from amazon.
    http://www.amazon.com/gp/product/B010CHLS6U
    Did some quick mockups in sketchup, then imported it to vcarve Desktop to add some pocket and profile operations.
Name:	Lit beer tap.jpg
ID:	92280 Click image for larger version.
Name:	Lit beer tap vcarve.png
    I output all the operations to one file since I was using a 1/8" endmill, however I need to get a longer bit since the ones I have taper to a 1/4" shaft, so I got some tapering of the cuts of the profile.
Name:	2015-09-13 15.47.20.jpg
    Here are some test of the LED with a piece of plexi glass, the led changes colors slowly.
Name:	2015-09-13 16.14.35.jpg
ID:	92283Click image for larger version.
Name:	2015-09-13 16.14.45.jpg
ID:	92284Click image for larger version.
Name:	2015-09-13 16.14.50.jpg
ID:	92285Click image for larger version.
Name:	2015-09-13 16.14.57.jpg
ID:	92286Click image for larger version.
Name:	2015-09-13 16.15.23.jpg
    I'll be redoing the recess on the back so the back plate is in a recess rather than covering the entire back. I'll also work the recess and hole for the light into the final design. I did a quick turn of the handle on the lathe to round out the base for the ferrule and found I had the width a little narrow, so will also widen that.
    I'm also thinking I can cut different shapes in the front frame rather than it just being a rectangle, so will be playing around with that also.
    Apr 2010
    North of Reno, NV...middle of the desert
    1,930
    What did I tell you, Darren, about giving Brent ideas...especially this time of year
    13,462
    Whoooo Meee???
  1. Custom Beer Tap Handle
    By Mike Mathieu in forum Flatwork Project Showcase
    Last Post: 01-11-2015, 03:07 AM
  2. A Beer Jocky Box
    By Stuart Ablett in forum Flatwork Project Showcase
    Last Post: 07-24-2014, 10:56 AM
  3. Beer tap handle parts
    Last Post: 07-18-2012, 04:16 PM
  4. Beer Tap Threads
    By Don Orr in forum General Woodturning Q&A
    Last Post: 01-09-2012, 08:08 PM
  5. sit back with a beer
    Last Post: 02-17-2010, 11:16 PM
