Page 1 of 6 12345 ... LastLast
Results 1 to 10 of 56
Thread: Stacked Text - Practice
    Thomasville, GA
    5,987
    After seeing a couple of items posted elsewhere, I decided to have a go at doing a stacked text plaque (sign, whatever). Below is my first practice piece in MDF.
    No attempt at any real finishing yet. The background was cut with a 1/4" end mill. Letters were finished with a 60° v-bit.
    In the close-up, you can see how the upper and lower text blend.
    I'm gonna have some more fun with this!!!
    Bill Arnold
    13,427
    Very cool Bill, I like the look of that.
    Dec 2008
    falcon heights, minnesota
    5,604
    Sweeeeeeeeeettttt!!!!!!!!
    benedictione omnes bene
    www.burroviejowoodworking.com
    Jul 2015
    Tahlequah, OK
    272
    Nice! I've been eyeing that and have printed out the instructions from the other forum. I've got to give that a try soon too, looks pretty neato!!!!
    Thomasville, GA
    5,987
    Quote Originally Posted by Robert Johnson View Post
    I tried for several days by using logic and I got close. But, there's nothing like the experience some of those other guys have. The instructions I printed out are eight steps that are very straight-forward and I still messed up! When I took a deep breath and went back through the process, I saw what I had missed and it worked perfectly.
    Bill Arnold
    13,427
    Would you mind posting a link to the info Bill?
    Thomasville, GA
    5,987
    The thread on the Vectric forum I found most useful is this one.
    I copied and printed the following from it:
    Stacked Text Process
    1. Create 2 Layers (Upper and Lower). Leave both visible.
    2. Create your upper text on the upper layer. Create another vector as a border, one that will be large enough to encompass both the upper and lower text. At this point convert the text to curves. You can now node edit the text to eliminate loops/artifacts, and 'weld' the touching letters together (if required). Group the entire text (but not the border), and hide the upper layer.
    3. Create bottom text on the lower layer. Convert to curves, edit and group the entire bottom text as you did for the upper text.
    4. Show the upper layer, then right click on the upper text vectors and border and select the copy to lower Layer option. This will send a copy to your bottom layer for welding. Once again hide the upper layer.
    5. Now select both grouped words on the lower layer (but not the border), and click the "Weld Selected Vectors" button (right below the mouse pointer button on the left side under "Edit Objects").
    6. Success! Now continue on to machining.
    7. Show the upper layer (hide the lower) and select the upper grouped text and the border. Create a V-carve toolpath. I usually cut the first layer to a depth of 0.05 with a 60º bit (tip ground down slightly (0.037) to pocket cleanly between the letters), and a 1/4" end mill for the large area clearance.
    8. Now show the lower layer (hide the upper layer) select your welded vectors and the border. Create a V-carve toolpath to a flat depth of 0.1 with the same bits.
    Bill Arnold
    Jul 2015
    Tahlequah, OK
    272
    Having read and reread the instructions I printed out (the ones you linked to below), I fully intend to screw it up a few times! That's my MO! Kudos to you for getting a great result, it's quite a design process and then requires successful machining!
    13,427
    Thanks Bill! Steps work like a charm...
    13,353
    Instructions on the internet I've found are usually a 'guide', at least for most things I try and do. What works for one person, or seems completely self explanatory, may not work for the next person. There's nothing like doing it several times and gaining experience and then you'll go, AHA, That's what they meant.
    It happens to me several times a week usually.
  1. Finished up stacked text and started a xmas gift
    By Darren Wright in forum Computer-Aided Equipment Project Showcase
    Last Post: 11-18-2015, 02:29 AM
  2. Another Stacked Text
    Last Post: 10-12-2015, 08:01 PM
  3. no text
    By Lanny Edgar in forum Carpentry and Construction
    Last Post: 01-11-2011, 05:06 AM
  4. Do you text?
    By John Pollman in forum Off Topic Discussion
    Last Post: 05-21-2009, 12:52 AM
